July 31, 201511 yr comment_699026 Just wondering if there is a gasket for the ke30 diff, do I use gasket silicone, or make a gasket. The car is a 1978 ke35 auto. I'm going to change the diff oil. Thanks. Report
July 31, 201511 yr comment_699033 The diff drain/fill plugs often don't have gaskets or washers at all. I re-use sump washers regularly without any problem. If you pull the whole cover off you can just silicon it back on. I clean the surfaces up with brake-clean and try to use as little silicon as possible. Report
