August 15, 201511 yr comment_699370 Rear drums suck. What would I need to do to convert them to disc's? Also, is there another set of disc's/calipers that I can use as a cheap big brake kit? Off a Camry, Celica etc. Report
August 15, 201511 yr comment_699371 Presumably there was an AE112 that came with rear discs. Find one of those at the wreckers and buy everything to switch over. I don't know where you are (update your profile), but there look to be a few of that year range at Centre Rd wreckers & also pickapart that you could check out. Report
August 16, 201511 yr comment_699380 Presumably there was an AE112 that came with rear discs. From memory the CSX, Levin and Ultima AE112s had rear discs, base-model Ascents and Conquests did not. Report
