August 17, 201610 yr comment_705929 Alright, i have a coolant leak, and it's not a hose clamp :/ The coolant has pooled on the hose there, but it is coming from the top. I'm new to this, so any help would be appreciated, thanks :) Report
August 17, 201610 yr comment_705930 That thing the two hoses commect to is the valve that lets hot coolant into the cabin for your heater to work. If it's leaking out the top it means the internal seal is stuffed. For a quick fix block both lines and remove, do not join them together. Your heater wont work if you block them though. Youll have to try and track downna new valve or retro fit one from another car. Edited August 17, 201610 yr by ke70dave Report
August 17, 201610 yr Author comment_705932 Alright, will do. Thanks for the help :) Where exactly should i block them? Report
August 17, 201610 yr comment_705933 Dave is spot on there. Quite common, & to be expected, when the rubber seals in the valve/tap are old & hard. Don't settle for a second hand one, as it will probably not last long. See if you can get a new one for the KE, but if not, there are plenty of aftermarket mechanically actuated ones, that are universal. Shouldn't set you back much more than $ 20, if these ebay listings are any guide. http://www.ebay.com....valve&_osacat=0 Cheers Banjo Edited August 17, 201610 yr by Banjo Report
August 17, 201610 yr Author comment_705934 Alright thanks guys, will try to block them off tonight. I'll look online tomorrow, thanks. Report
August 21, 201610 yr Author comment_705966 Alright picked a universal heater tap up from autobarn, $30, drained coolant, chucked it in, put coolant back in, started and no leaks... yet Still have to rig up a mount for it, but should be able to do that at school. Thanks for your help :) Report
