October 10, 201610 yr comment_706589 I purchased a seal kit for the fuel pump in my 3k. However upon dismantling it, the diaphragm seems to be attached permanently and doesn't seem to have a way of being removed. Has anyone else had this issue? I have a NOS goss kit, part number 955kt which is supposed to be for a 3k. Report
October 10, 201610 yr comment_706590 Hi Nathan, Off memory, after separating the two (2) halves, you twist the diaphragm 90 degrees, & it pops out. Re-installing is the reverse. Cheers Banjo Edited October 10, 201610 yr by Banjo Report
October 10, 201610 yr Author comment_706593 Hey Banjo, Thanks for your reply, however I have tried this and it didn't budge. It just feels like somethings going to break rather than come apart. Report
October 10, 201610 yr comment_706594 Nathan, Just looked up the "yellow" Toyota 3K bible & it doesn't help. Only tells you how to test it. How about trying to remove the lever arm, by driving out the pivot pin, & then extracting the lever arm. When I'm down the shed in an hour or so, I'll have a look, as I'm sure I've got one stripped down in a box somewhere. Cheers Banjo Report
October 10, 201610 yr Author comment_706595 Ahh thanks for having a look, much appreciated! As for taking out the pivot pin that was going to be my next step, but surely Denso designed these to be servicable easier. If you have one let me know how you go. I'm trying to upload a photo or two but am using the mobile version from my phone at the moment. With luck a photo should upload with this post. Report
October 10, 201610 yr Author comment_706596 Damn, no luck with the photo. Here is a link to the same as the fuel pump I have here in pieces. I have a 4k here also but the pump is slightly different with just barbed fittings rather than the threaded fitting on the 3k pump. http://m.ebay.com.au/itm/New-OEM-QUALITY-Mechanical-Fuel-Pump-For-Toyota-Corolla-KE30-KE35-1-2L-3K-C-/151771433480?nav=SEARCH Report
October 10, 201610 yr comment_706598 if i remember rightly, you push down on the diaphragm and sort of push forward to release it. The pump lever arm has a hook and the diaphragm arm has a slot. Report
October 10, 201610 yr Author comment_706601 Thanks for the suggestions guys! I ended up having to drill one of the retaining balls out so I could punch the pivot pin out. Wasn't the most fun I've had but another job done. Report
