Ivan's Ae101 Build Thread 4Age Bt 20V 6Spd Lsd Shaved Tucked Engin
Inspecting The Work "done" At Home 9-16-13
  • Replies 269
  • Views 30.9k
  • Keeps getting better. The amount of effort astounds me.
  • Only just came across this and had a quick flick through, looks interesting so I will save a good read for later.
Brake Set Up Test Fit 9-17-13
Measuring to Customize the bracket and get it centered...
Going To Sandblast 9-26-13
Not Happy with the final result after few coats of powder coating.
Not like the finish and ends up not the color I choose...
Choosing the Color Variants For The Car 10-2-13
3 different Colors With the same code. and each one have at least 2 variants...
Going to TitoAutoPaint 10-23-13
Picked At Home...
Arrived To TitoAutoPaint & Inspecting With His Kid...
Sanding and De-Ruster 10-24-13
Sanding all the Engine bay to the metal...
Spending Time on facebook until the de-ruster work on the metal...
Brake Braket Modified Test Fit 10-25-13
Modified Bracket
Test Fit to get the new Big Rotor Centered
Perfect Fit!
More Sanding and De-Ruster 10-25-13
Working the other side of the Engine Bay
More De-Ruster Treatment In Action 10-26-13
TitoAutoPaint Taking a Break 10-29-13
More Engine Bay Work 10-30-13
Wheels All Coats of Powder Out 10-31-13
Since I wasn't happy with the powder coating texture color and coats...
All Coats Removed... Wheels Sand Blasted...
Power Steering Delete 10-31-13
Self Etching Primer For Nude Metal 11-3-13
