May 9, 20179 yr comment_709411 Hey guys, ive had a look around the forum and online and can't really find an answer I removed the ignition barrel just out of curiosity and it cycled though acc-start quite easily.But when i moved the key to the :"lock" position it became fully jammed. No matter how hard i try turn it, it wont move at all and i can't reinstall it unless it's in "ACC". Do you guys have any advice that i can try to get it unstuck? cheers guys Report
May 9, 20179 yr Author comment_709413 i don't want to gunk up my barrel. maybe as a last resort Report
May 9, 20179 yr Author comment_709415 alright so i fixed the issue. For future reference: In order to move it out of the lock position, normally you'd press the button on top of the column nut with the barrel removed, you can't. so you need to really jam the key into the hole ( ;) ) and turn with a fair amount of force. that should break through. After that you're sailing just don't put it back in lock. Report
