AE112R / 7A-FE intermittent idle surging, fault code 31
4 hours ago, Hiro Protagonist said:
Don't think the idle speed is meant to be manually adjusted via the screw on a 7AFE.
Yes I've read this too.
The screw I refer to is behind the throttle arm, and appears to simply change where its resting position is. Is that the scree you are referring to?
  • 7 years later...
  • Replies 61
  • Views 16.9k
