May 1, 200620 yr comment_115209 Can anyone point me to a 16v 4a-ge wiring diagram in english? I have a smallport motor in a ke20 which i'm trying to finish before July. I seem to have looked everywhere on the net and can't find one. I can find a 4a-gze one but no 16v diagrams. Thanks, Jon Edited May 1, 200620 yr by JC807 Report
May 2, 200620 yr Author comment_115439 I got given the 100kw 4A-GE MAP sensor EFI, starting and charging wiring diagrams by the helpful guys at a performance workshop. I will scan them into the computer if anyone needs me to. Report
May 2, 200620 yr Author comment_115472 you mean the ae86 manual? I couldn't download the file for some reason and assumed that it would be the AUS ae86 with AFM. I wanted the 100kw MAP sensor diagram. Anyway, got it all sorted out now. Report
May 2, 200620 yr comment_115474 Undo the 4 screws and remove the lid off the ECU, all the pinout codes are on the PCB, take a close look. also go to http://www.club4ag.com/technical_main.htm that site should have the works.. Report
May 3, 200620 yr Author comment_115553 when i looked a week ago at the club4age site, i could only find a ae92 diagram in Japanese. I was going to order a Haynes/gregorys manual but the guy at the shop said it didn't have any useful major diagrams. If i need anything else i will churn at the 90mb file, i assume its the toyota manual? Report
May 3, 200620 yr comment_115554 Just read the pinouts off the ECU circuit board, Thats how I've done my engine so far.. Report
May 3, 200620 yr Author comment_115563 the file at toymods called: 4A-GE100kW[1].tar.gz has the wiring diagrams too, i just couldn't seem to download it last week at 28.8kbps but now the cable modem is fast again. I knew you could use the pinouts but I prefer to scan over a diagram when doing something i've never done before to get a feel of how it all works. Report
