October 23, 20178 yr comment_711805 Hi Guys, I have a 79 KE55 and recently picked up a pair of 1 1/4 su's for it. I have done some digging on this forum and see that unless i build a "Tough" K motor that they won't be any good with a stock setup? Does that still ring true? Report
October 23, 20178 yr comment_711820 I'm no expert, but a 1.3 litre designed for less than 80 hp is no place for 2 x 1.25 inch carbies, especially SU. atomisation of fuel is the problem. i can't give u any solid figures but i just feel that its going to constantly bog down. ive used a single su and threw it in the bin. but now ive given u the amm9 to prove me wrong, and u have the carbs so make it work Report
October 23, 20178 yr comment_711823 I use them, but as typical I've done a porting job, raised the compression, fitted a ground cam & extractors. Definately its faster and uses less fuel, and the SUs are very tuneable. They come off a 1L Austin Healey Sprite or a 1L Mini Cooper, amongst others. They won't bog down, you can tune that out of them, but I don't know if they are any better than the Asian. Give it a go and see. Report
October 24, 20178 yr comment_711830 there is 2 of them ona 1l engine :o haha wow. that puts my theory to bed. Perhaps my experience is with a Junk SU. i couldnt get it (a single downdraft SU) to operate efficiently, or even close to effectively. interested to see how it goes and i hope u can learn enough about it urself to tune it good. Report
