whereabouts are you josh? I'm in toledo , cebu.
u need to let the guys here know exactly which 4k u have, but even better still, because of all the rebuilt motors here in the philippines, u really need to confirm which pistons are actually in it now.
Mine is a 4kU which happens to be quite popular here, with the D shape dished pistons. have a look with a flashlight down ur spark pkug holes and see if u can see a dish on the crown.
i believe u should get a bit better compression from flat top pistons but I'm not sure that it would be worth it unless you allready plan to have the engine apart.
whatever u do, make sure you change the spark plugs to suit the new flat pistons.
