Fix headlight gaskets??
Gday,  I'm having trouble keeping my headlight gasket things in?  I have a corolla with the cute little round headlights but the ring that fills the space between the light and the bonnet keeps coming out. I'm not sure if it originally came with clips to keep it in place. Any advice would be much appreciated :)
On 1/31/2019 at 7:53 PM, parrot said:
I think I know what you mean but suspect it would be a good idea to post a picture. Helps to know the model also.
Shes an 1998 AE112R Conquest
20ECC8D2-4DCA-4655-A4D9-8601EFE8847D.thumb.jpeg.4e43f92cb995e3a209c2d62d5235a5b8.jpegIt doesn’t look like there are any clips. I suspect it just sits there.
I reckon you need to take the light out so you can fit the sealing ring over the ridge on the lamp body itself properly. It looks like you only need to remove one retaining screw for the assembly.
Edited by parrot
Double upload
Thanks so much. I really appreciate it
Sorry i couldnt thank you sooner. It stayed in for about a day before it popped right back out again unfortunately 😞
