June 1, 200620 yr comment_120828 ok first of all, hi!! :S Just found this site today after browsing the net. I never knew the site existed, and hve found out alot of useful info frm much reading. I have a 1980 ke70 her and its only done 40000 km from new, not bad for a 26 year old car!! Sorry that my first post is asking for help, but thats what led me here in the first place! ok, I am puting a 4age into my KE70. At the moment, it has a 4 speed 4k in it. Now, I know that to put the 4age into the KE you need the ae86 x member, and the t50 gearbox x member aswell, whish is all good. Also, I know, that as the T50 is a hydrolic I need the clutch pedal and the clutch master cylinder to make the clutch work. so far, so good. Let me know if I have missed anythng. Now my big worry, is making my ae86 coilover fit on my KE70. What do I need to make them fit??? I know that I need AE86 hubs, calipers. do I just need the ae86 steering knuckles?? Pleae let me know what I need to make it all fit. I was hoping that I can just keep the std KE70 steering rack and TCA too. I tried a search and could find anything re this but sorry if I overlooked it when I did search. I understand that what I think is right is ok, but its always best to get a second opinion!! so, as I have ranted on, just to make it clear, WHAT DO I NEED TO FIT AE86 SUPSPENSION ON A KE70?? thanks is advance dudes. Cheers Adam :P Report
June 1, 200620 yr comment_120829 I'm crying because you want to take a knife to such a rare, clean, overrated example of a ke70 :S :P !!! Have a look at this... http://www.rollaclub.com/board/index.php?showtopic=5644 Report
June 1, 200620 yr comment_120830 alot of 86 parts will swap into the ke70/ae71. With the sruts i belive that the strut hats are backwards (mine were when i got my coilovers). Appart from that you may need to sway the steering parts I'm not so sure, becuse i just used corona parts Report
June 1, 200620 yr comment_120836 Yes you can keep the existing steering rack and KE70/AE71/AE86 suspension is interchangable. Report
June 2, 200620 yr Author comment_120915 Cheers peeps!! :monkey: just he info I needed!! Ok I do have another question though. I know that once the engine is sitting in the KE (4age) on the gear box x memeber and engine x member, but what I am unsure about, is once its sitting there, what is needed to actually make it work?? If we forget about the wiring for now, what I am concerned with is things like throole cable, speedo cable, heat controls etc. And also, like the rad fitment (will use a AE86 one) What do I need to get in preperation for my conversion as I will be obtaining all the parts this week you see, and don't want to find I am missing anything in the process. I have looked through lots of other posts here but I just couldnt find anythink very detailed on the 4age conversion. ANY INPUT PLEASE :) Cheers Adam :P: Report
June 2, 200620 yr Author comment_120966 thanks mate that was useful! :) didnt notice it before :monkey: Report
