June 3, 200620 yr comment_121087 If you have the SC in the car then NOOOOO Way dude. But the I guess I could bet you that you will win........ :monkey: Edited June 3, 200620 yr by Trendact Report
June 4, 200620 yr Author comment_121104 I thought the "Mmmm Boost" title would have given it away Report
June 4, 200620 yr comment_121109 I thought the "Mmmm Boost" title would have given it away Welll it did BUT wasn't it already S/Charged Report
June 4, 200620 yr Author comment_121111 Oh ok sorry... No the SC hasn't been on the 5K for a few months...I had a head gasket issue...but it's back on now and oh so fun Report
June 4, 200620 yr comment_121116 Oh ok sorry... No the SC hasn't been on the 5K for a few months...I had a head gasket issue...but it's back on now and oh so fun HOW MUCH PSI!!!!!!!!!!!!!!!! Report
June 4, 200620 yr Author comment_121117 I have no boost gauge at the moment...but last time it was on it was 4psi...It's still the same pulley and everything, so I assume it's still 4psi Report
June 4, 200620 yr comment_121118 I have no boost gauge at the moment...but last time it was on it was 4psi...It's still the same pulley and everything, so I assume it's still 4psi Argh you woos,turn up the heat man. :monkey: Report
June 4, 200620 yr comment_121126 I will be. I need a new crank pulley...gimme a break Ive heard that the falcon aircon puuley from a el will fit on the charger and give more boost,(smaller) NEVER rest in the search for power man. Report
June 4, 200620 yr Author comment_121141 I can use a VL pulley (can't remember which right now) on the crank and it should run 10 psi, which will be fine for now Report
June 5, 200620 yr comment_121445 i,ll give you a run maaaate! just give me a weekend to stuff in the new motor and charger Report
