June 29, 200620 yr comment_125920 Guys can you please tell me how to contact an admin,as i need to locate a particular member Report
June 29, 200620 yr comment_125931 http://www.rollaclub.com/board/index.php?a...ts&CODE=leaders Try That. If you looked hard enough, you would've found that if you clicked on message board up the top and scrolled down to board statistics there are a series of links under that header and one says "The Moderating Team". Edited June 29, 200620 yr by Raven Report
June 29, 200620 yr Author comment_125945 http://www.rollaclub.com/board/index.php?a...ts&CODE=leaders Try That. If you looked hard enough, you would've found that if you clicked on message board up the top and scrolled down to board statistics there are a series of links under that header and one says "The Moderating Team". Ok remember that for next time. Cheers Report
