TURROLLA Posted October 28, 2022 Report Share Posted October 28, 2022 Hi all, Have just begun my project of 20v turbo 4age into my rolla currently looking at diff options and wondering if this would be suitable. I know the factory length of the ke70 diff is around 1410mm but this one should be ok as long as it clears the inner wells ? Cheers Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted October 28, 2022 Report Share Posted October 28, 2022 I took the easy route and used a Celica, also wider but nowhere near the arches with stock rims. However the Hilux seems to be the most common conversion, although if you're at a wrecker take a look under the newer vans. There are 5-linked rear diffs with disc brakes under some of the vans, and they look lighter than the Hilux. Quote Link to comment Share on other sites More sharing options...
