February 4, 20233 yr comment_735111 Short and sweet I'm trying to track down an idler arm for a 77 KE30 4DR. I have gone to numerous shops and ebay with no success any help would greatly be appreciated. Report
February 4, 20233 yr comment_735116 I had a look in my heap of spares, & I do have an idler arm pivot assembly, out of a KE55. I can't imagine, Toyota changed that much throughout the KE30-35-55 series. I was going to compare it, with my KE30 2 door coupe one today, but it was raining, so couldn't put my KE30 up on the ramps, to take a look. If it's fine tomorrow, I'll take a look. This one is missing the phosphor bronze bush in the middle. I'll take a look through my heap of bits tomorrow, & see if it is there somewhere; or maybe I've used it previously, but can't recall. Edited February 4, 20233 yr by Banjo Report
February 6, 20233 yr comment_735148 I found another one in my garage, & had a quick look. I stand corrected. It does not have a phosphor bronze pivot sleeve bearing in it. It has two (2) tapered nylon bushes, one at each end. New bushes are about $ 30 a pair on ebay. I did however confirm, that the idler arm bracket, fits all models from KE-30, through to KE-55. Unfortunately, the idler arm ball joint is not replaceable, & if the ball joint has failed, you need to replace the complete pitman arm, which incorporates the ball joint. Both items; complete idler arm assembly, & the pitman arm, are available on ebay. Cheapest I saw the complete idler arm assembly was about $ 60.00. The pitman arm, including ball joint, was about $ 40 - $ 52, so on that basis, it would be wise just to pay the extra dollars, & obtain the full new assembly, & get everything. Cheers Banjo Edited February 6, 20233 yr by Banjo Report
