August 25, 20251 yr comment_738317 Hey All, After some wisdom, Manged to get my hands on a KE55 Coupe K50. Now my question is is the driveshaft in my KE55 sedan (K40) the same will it all bolt up? terrified i will pull the K40 out and it wont fit appreciate the input (sorry if this is already answered) cheers Slender Edited August 25, 20251 yr by SlendermanAU Report
August 25, 20251 yr comment_738318 Hi Sam, I had a 2 door KE-55 Couple. It had a 4 speed manual GB in it. I fitted a K50 5 speed gearbox. It used the same tailshaft, The KE50, went to "Rust Heaven". I bought a 2 door KE-30 2 door sedan, with a 3 speed auto. Out came the auto, & in went the 5 speed manual box, along with the same tailshaft. I'd have to sit down with the factory manuals & dig out all the linear distances between front & rear axle centers; but I'll think you'll find if they aren't exactly all the same; it will only be a few millimetres between them. I've got a spare tailshaft in the shed. I'll measure it tomorrow, & let You know whether it is different, to the one in my KE30, with the K50 GB. Cheers Banjo Report
August 26, 20251 yr comment_738319 Hey banjo thanks for the quick reply, I think I need to word the question better….so I’m trying to put the k50 from a ke55 coupe into a KE55 sedan that is factory k40 I don’t have the tailshaft out of the coupe just the shaft on the k40 basically just wanted to know if it all fits together or do I need a 5 speed tail shaft as well ? thanks again guys cheers Sam Report
August 26, 20251 yr comment_738320 Not sure what is happening I must have signed up twice and now my phone is logging in on which ever it wants to at the time sorry for any confusion Report
August 26, 20251 yr comment_738321 22 hours ago, Banjo said: I had a 2 door KE-55 Couple. It had a 4 speed manual GB in it. I fitted a K50 5 speed gearbox. It used the same tailshaft, I think this answers your question? Report
