May 25, 200422 yr comment_10106 had a few hassles getting my son to school this morning. driving along and the car starts spitting and farting like it was running out of juice. the fuel guage was low, so i assumed it had run out of fuel. the car stopped, so we went for fuel. get back, put a tin of fuel in and the car starts first pop. weird, it should have taken longer for the fuel to pump through. anyway it is still doing the same thing. i work out if i give it full throttle and slip the clutch i can still get places. anything below full throttle and it would just die. after i got home i started the car and sprayed carby cleaner around the base gasket, the engine instantly stopped. ah, major vacuum leak. one of the 8 studs on the adapter plate for the DMTT weber had stripped. i found another one long enough to put a nut underneath, problem solved. the car runs so much better, and i can now set about sorting this carb out properly. some pics of my afternoon project below. bit rough, but for the money who cares. Report
May 25, 200422 yr Author comment_10108 pics didn't work :P try these...... probe1 probe2 probe3 Report
May 25, 200422 yr comment_10109 i just coppied the link into the brouser, and that worked! missing bolts.. running ruff... this rings a bell ! lol Report
May 25, 200422 yr comment_10119 now that I have a nut on every stud holding the weber on :P always a good thing!! Report
