Retrospekt Posted September 16, 2006 Report Posted September 16, 2006 Hey guys, did a search but didnt find too much help with this. I need to move my Brake master cyl or use a smaller one, after i swap in new engine the ends of the carbs will be abit close so i either need a smaller one (length wise, bring it close to firewall) or be able to move it. don't want anything silly, scared of anything sketchy on cars. Thanks for any help, Nathan. Quote
Raven Posted September 16, 2006 Report Posted September 16, 2006 I found that the 1985 model barina/swift uses an Aisan Booster with remote mount reservoir and its pretty slim. Probably sticks out about 3 inches at the most and then you ahve your master cylinder on it. Then again, you ask a question about brakes but we don't know what car it is! Quote
Retrospekt Posted September 16, 2006 Author Report Posted September 16, 2006 Oops sorry, ke55 sedan. Quote
Rolla__Boy Posted September 16, 2006 Report Posted September 16, 2006 Try and find a KE30 setup Quote
Redwarf Posted September 16, 2006 Report Posted September 16, 2006 What enigne are you fitting? Quote
Retrospekt Posted September 16, 2006 Author Report Posted September 16, 2006 2tg with delorto's. i know it would fit but i don't like how close they come. Quote
Raven Posted September 17, 2006 Report Posted September 17, 2006 Then shorten the bracket it sits on and make an adjustable pushrod so you can vary the length of the rod. Quote
