Leaderboard
Popular Content
Showing content with the highest reputation on 11/25/17 in all areas
  1. Hi James, greetings from Costa Rica! From my experience: - Yes, is easier to fabricate a new metal wheel arc than buying one, it isn't that difficult. Unless of course there is a scrapyard near your location with any KE2x over there, but I believe is most likely to find gold in your home garden! - Are you refering to the upper soft vinyl part of the dash? Time to time, you can buy an OEM part on eBay, but be ready to pay the price (but with 40+ years of service, it is reasonable) https://www.ebay.com/itm/TE21-TE27-TE28-Toyota-Corolla-NOS-dash-pad-1971-1972-1973-1974-ke20-ke25-ke26/322376981566?fits=Make%3AToyota&hash=item4b0f2a5c3e:g:ZlsAAOSwDNdV0QyC&vxp=mtr - Is your engine a Toyota K series? 3k (1200), 5k (1500)? Or a T series? Is posible to tune a Weber 40 for this engines, but is easier do it with a set of Weber DGV 32/36 (good torque, increase hp with good MPG). Now, if you want power with reability, always is better to put a modern engine, like a 4AG (140+ hp)...but you need to make new engine mounts, new gearbox (T50), a good differential, and if possible updated suspension, and of course, brakes. - I installed a Toyota Hilux brake master with servo, but had to make an adapter plate of 3/8" steel, with holes for both the firewall and the brake master base. Also, I fabricated a new longer pin from the pedal arm to reach the master. - On eBay, you can buy front and rear fiberglass spoilers based in TRD ones, here are the links https://www.ebay.com/itm/JDM-Toyota-Corolla-TE27-TE25-KE25-KE20-rear-wing-duck-tail-Spoiler/182885284655?hash=item2a94cffb2f:g:7YIAAOSwrklVClcM&vxp=mtr https://www.ebay.com/itm/JDM-Front-lip-spoiler-for-TOYOTA-COROLLA-KE20-KE25-TE27-sheet-metal-1-32/232563221392?hash=item3625d92390:g:ROQAAOSw7bpZjzPE&vxp=mtr - Other places to check for rust: front fender's low anchorage points with the main body, lower door's rocker panels, the lower radiator frame, the weld seam between the inner rear wheel arches and the main body, and the airbox floor (for me, the airbox is the part above the firewall where the plastic air intakes are, and the external air is draw into the cabin). This last one is especially important, because with over 40 years, and no corrosion protection in this zone, the water can found it's way to the cabin, soaking the floor mats and leaving that moisture smell I hate so much :( Hope this can help you, and welcome to the KE2x and TE2x owners club!!! José Garro, Costa Rica
