47 -
Everything posted by kurts1
Hi guys, I am running a stock 4age coil with hyperpak ignition computer... I am just wondering if i have to use the factory ignitor with this set up? Thanks P.s. i am getting 12 volts out of the coil but wondering if it makes ant difference to use the ignitor? Cheers
Yea its still on carbs... I'm just guna trace the wires back and see how i go! Cheers for help!
Hey guys... I'm currently wiring up my 4age conversion into my ke70... I have extended the positive and negative wires onto the opposite side as the dizzy is on that side... my problem is that when I put a test light on them and turn the ignition on i get no light turning on... hmmmm Is there a possibility that the ignition relay or fuse is broken? or i currently have my dash out.. could there be a connection in the wiring loom/harness that is disconnected at present? Any help would be appreciated! Cheers
Valves all lapped up! Should have engine all built up by the weekend !
You probably could mod them maybe? it looks like the back could pull away from the glass but not sure... they definitely look good though
You can replace the bulb... the bulb that does normal beam has its high beam filament blown so the lights are sweet until you go to put on your high beams then in switches the inside one on and the outside on off.. so i figure its best for a fresh start!
Yea guna rust proof all up there so will end up being a black colour!
Let me know what you guys think and ideas I'm allways looking to improve things! Thanks
How the quads look... Still need to put Chrome bumper on... Number plate just zip tied for testing out suspension!
well its been a while since i have updated this.. Lots of progress has been made... Coilovers welded up.. Bottom end rebuilt... (should have head done in a few day Coilovers in...
Yea this hyperpak ignition setup seems like the way to go! think i'm going to buy one very soon! I'm guessing its rather straight forward to setup? Thanks for help...
Hello everyone... I am currently trying to get my 4age ignition sorted out! From want i have been reading i have been led to understand if i set up my stock 4age distibutor and coil with a GM HEI IGNITION MODULE it will work... Can anyone confirm this for me? Also what are some other budget options for carbed 4age ignition? Any help will be appreciated Thanks
Thanks Carb setup... have ditched throttle bodies as of expense of setting up! cheers
Ok Haven't updated here for a while... Lots has been going on with the car... Its all sprayed up (Just needs to be buffed) And then should be looking good... Have also got all the bits for the coilover conversion so that will be going in soon... Got the leafs reset with an extra leaf added so it sits pretty nice in the rear at the moment...! And engine work has started... Have decided i am going to be running it on mikuni carbs... Just for ease of setup so hopefully it all goes together well! Thanks Let me know what you think!
Anyone know? Thanks
no its definitely a 4 door ke70 wagon with a 4k... the original owner could of possibly swapped the struts? even though it was a complete stocker when I purchased... anyway I have added a picture just to show you guys.... Hmm I'm confused... hopefully they are ae86 struts but I really don't know.... Thanks for any help... Cheers
Hey guys... I have a late model ke70 wagon and am converting the struts to coilovers.... my question is if i buy a ae86 strut insert/shock and shorten my strut tubes are these going to work for me... I have measured so my strut tubes and the width of them is 51mm so i searched up the width of a ae86 strut and apparently thats 51mm aswell so i put to and to together and thought why will these not work... Has any one here done this before... Thanks Any help appreciated
