108 -
Everything posted by ToDa30/4
Hey Thanks Guys ..still putt'n around Mick :S
where to get a NEW pair please or will a later or other model fit ?. local auto shop tells me there not listed anymo :S
LOL cheeky ,not seen u again ,you must be hiding :lolcry:
Spotted KJ's rollas coming to help me out stranded with a fuel problem . :hmm: CHEERS Mate :y: . got the poo car home . now the fixing part ;) where to start :)
No cruz for me . the ke has developed a miss on the way back from reynella this arvo ,time for new plugs & points :)
I'll See uuu's at bunning 7.30 ish
Rollaclub Christmas Party - Barossa Valley
ToDa30/4 replied to KJ's Rollas's topic in The Event Archive
I'm IN . great idea :) -
not u aye , main noth rd ,grove way lights .was a girl driving dark hair , i was behind & i turned right onto grove way , u got a twin :cool:
did not take long to bianca gray KE with the ubber spoiler at the grove way lights today around noon :cool:
will try to make it will know closer to the night cheers dave
yeah around $50 bucks a set of moonies if anyone i interested , i like globes too ,i am looking for a set of Hustlers . as shown in the cheesy little pic attached
UP BY THE HIGHLAND SHOPS TARGET HILL RD.
HAHA your right ,see what happens when u get old :D
I'm getting bored here guys !. don't believe everything posted on offical sites ,lots of firfeys are told by corperations ,do we have a whats the fastest car YOU own thread , if not lets :D
stock 2nd gen 3sgte rods & crank balanced , etc.& stress relieved by Chris Miltons good for 9500 rpm , best pull was 225 awkw @8000 rpm on a hybid CT26/ GT30R , ran on the street at 205 awkw had all sorts of dramas with the internal gate not holding preasure , so now have fitted the GT35R externaly gated , we hope to get around 300 awkw on the 264o cams if not i will swap out the cams for some 272o hks & do the shimless 1zze conversion so i don't loose the std bucket over shims with the higher lift . car is going thru a rebirth at the mo & will be back together , on the dyno & the track april 07 cheers dave
Originally Posted by ToDa30/4 This car has done 245 kmph, ive had the GT4 6 years ,started off with the usual mods we all do and got carried away,motor built by Chris Miltons in Adelaide ,fabrication ,install & dramas sorted by Mark Mills of MADAZ Motorsport ( Top Guy ) and myself remote oil filter simmons 16" F90's Toyo Gran Trampio 225/45's ARP fixings thru out braided brake lines HKS pistons HKS valve springs HKS 1.6mm head gasket HKS 264o cams both sides HKS adj. cam wheels JUN titanium retainers Ferera 1mm o/s s.steel necked valves Bronze guides TRD thermostat Unorthodox alloy crank pulley Fererra Alloy fly wheel Extreme 5 puc single plate clutch ,good so far maybe twin plate latter Speed Source braided clutch line & slave cylinder rod Speed source brass gear link bushes TWM short shifter Fensport alloy pullies RMR alloy bell mouth plenumrossmachineracing.com stock 55mm. t/body ,have a ford 70mm to go on Madaz custom duel feed fuel rail 800cc side feed inj. XS hi preasure Fuel reg. Walbro fuel pump Aussie headers Aussie 3" dump HPC treated modified for GT turbo outlet 3' straight thru exhaust ,with a cannon with 41/2"outlet 10mm Top gun leads Link plus ECU Crane ignition module HKS elec boost control White line full suspension kit with front strut brace Kings super low springs Koni adj. strut insrts DBA slotted discs x4 lucas pads , may need to upgrade here AH UK. Ltd FMIC 645 x 160 x 95 ,600hp rated Garrett GT35 600hp b/bearing turbo Tial 38mm. waste gate twin 12" elec fans custom 4" alloy turbo intake K& N 4' x 5" pod Velo rece seat cam lok 5 pt. harness GFB bovus maximus BOV cusco lower front brace custom rear strut brace , Ok thats about it plans are I'm stripping the car out to get as light as i can, will be using the car for ANDRA sports compact Sports AWD class , run it at mallala & the collingrove hill climb, i had to put the project aside but am now back into it ready for the track april 07
a few more pics , gt35r fitted just ![Originally Posted by ToDa30/4 had the GT4 6 years ,started off with the usual mods we all do and got carried away,motor built by Chris Miltons in Adelaide ,fabrication ,install & dramas sorted by Mark Mills of MADAZ Motorsport ( Top Guy ) and myself remote oil filter simmons 16" F90's Toyo Gran Trampio 225/45's ARP fixings thru out braided brake lines HKS pistons HKS valve springs HKS 1.6mm head gasket HKS 264o cams both sides HKS adj. cam wheels JUN titanium retainers Ferera 1mm o/s s.steel necked valves Bronze guides TRD thermostat Unorthodox alloy crank pulley Fererra Alloy fly wheel Extreme 5 puc single plate clutch ,good so far maybe twin plate latter Speed Source braided clutch line & slave cylinder rod Speed source brass gear link bushes TWM short shifter Fensport alloy pullies RMR alloy bell mouth plenumrossmachineracing.com stock 55mm. t/body ,have a ford 70mm to go on Madaz custom duel feed fuel rail 800cc side feed inj. XS hi preasure Fuel reg. Walbro fuel pump Aussie headers Aussie 3" dump HPC treated modified for GT turbo outlet 3' straight thru exhaust ,with a cannon with 41/2"outlet 10mm Top gun leads Link plus ECU Crane ignition module HKS elec boost control White line full suspension kit with front strut brace Kings super low springs Koni adj. strut insrts DBA slotted discs x4 lucas pads , may need to upgrade here AH UK. Ltd FMIC 645 x 160 x 95 ,600hp rated Garrett GT35 600hp b/bearing turbo Tial 38mm. waste gate twin 12" elec fans custom 4" alloy turbo intake K& N 4' x 5" pod Velo rece seat cam lok 5 pt. harness GFB bovus maximus BOV cusco lower front brace custom rear strut brace , Ok thats about it plans are I'm stripping the car out to get as light as i can, will be using the car for ANDRA sports compact Sports AWD class , run it at mallala & the collingrove hill climb, i had to put the project aside but am now back into it ready for the track april 07attachment=13251:Picture_128.jpg]
:P this thread needs life ...meet my GT4 1990 ST185R aussie delivered 205 AWKW @ 8000 rpm on a hybrid CT26/GT30R turbo ,264o cams ,550cc inj & link plus ECU ,i have a list if you would like i can post it up ... car was busted badly for mods & i have taken it off the road to make a dedicated track car . its in bits at the mo & will be up & running April new mods include a externaly gated GT35R turbo ,800cc inj. open exhaust & a cusco front lower brace, its made 245 kmph , & was pretty quick over 400 mtrs & has bettered a known 13 sec WRX . ok i'll post up the new look with stripped out interior & uber mods when its done in about a month . cheers dave
Were To Get Leaf Springs Reset In Adelaide
ToDa30/4 replied to ToDa30/4's topic in KExx Corolla Discussion
most evenings i am around after 8 or any saturday that suits you :yes: Dobby & dweezil"s first date about 18 months ago :D -
Cheers Scott ,i have lower front springs & gas inserts & shocks to go in the ke very cheap ,so i reckon money spent on the springs is in order. i reckon your suggestion of inverted eyes & an extra short spring on top is the go , i just need to suss out in my mind who will do it . thanks Dave :yes: Random pic :D my mate Dweezil the weasel , he's a sick boy with cancer ,been a good mate ill be sorry to see him go. -
Cruise/drive-in Night @ Gepps Cross - Sat. 10th March
ToDa30/4 replied to Raven's topic in The Event Archive
A1 cruz & night at the drive in , has to scoot after the first so cya to all the new peeps i met, Lesley dusty yeah but we got to see were fords go to die ;) skirmish sounds good cheers dave & tom :P -
Lookin' good could u bring some rollaclub decals Mick id like 2 if poss cheers dave -
Hi Rob any word from pedders mate chees dave
