Ke30 Brakes
If putting 4 piston brakes do you need to upgrade the master cylinder or will the standard one work ??
7K Into My Ke30
What sump and gear box will be good ?
7K Into My Ke30
I've been looking at all of the writing and trying to work it out I'm just wondering can I bolt my 4 speed 3k gearbox straight up to a 7k engine And are the gearbox and engine mounts the same and two more things does a 5k manifold bolt straight up to a 7k engine and lastly can I bolt my 3k sump straight up to a 7k engine What do I need to do/change for each think Thanks jack
Help Please. What Is Needed For A 3K To 4K Engine Swap
Hey I need to no befor I buy what do I need to change to put a 4k in my ke30 Can I use the 3k gear box on 4k motor And are all of the wires the same So what do I need to change ??
3K Motor And 4K Motor Harness
Thanks
Hey looking at a 4k engine for my ke30 does the wire harness hook straight in ?? It do you need to change stuff
Needing Ke30 Dash And Need To No Wheel Sizes
Thanks guys
10Second Street Ca18Det Ke55
Are they 16" rims and what offset
Hey looking at the wheel sizes Did you have have role the guards or anythjng
Hey I've just brought a ke30 - picking it in about a week Does anyone have a Un cracked dash that they would sell and I'm looking at wheels to put on it and need to no what will fit (size - width - offset) Please
Jack32
