matty555
  1. Engine mounts and trans crossmember done. Now to take the engine and box back out and continue with the rust repairs
  2. Yeah, a bit taller than I originally thought. it's sitting as low as possible now and still not much clearance under the bonnet.
  3. Decided to cut the firewall a bit more and mount the BEAMS a little further back. Hopefully get the engine mounts and trans crossmember done tomorrow
  4. Windows are polycarb/lexan. I was thinking about cutting the firewall and mounting it further back but I reckon it should be fine how it is.
  5. Engine mounts had already been cut up from previous owner so i decided to cut them all the way down and start from scratch, mounting as low as possible. Some minor trans tunnel modification to fit the 6 speed in. Roll cage will well and truly make up for the strength lost in cutting the tunnel.
  6. I'll look into doing something like that while the rest of the car is away getting the cage built. I want to have opening windows
  7. Doors are 1155mm along the center line
  8. Think they are a little bit shorter than panel van doors. Will get proper measurement in the morning.
  9. Once motor and gearbox mounts are done I'm going to finish off a few rust repairs, then she will be going away to get a full proper cage built with intrusion bars
  10. Not a panel van door. Probably would have been a lot easier tho
  11. Yeah, would hate to need to replace one of the doors . I'll pull one of the doors cards off and have a look inside. They are quite heavy so I'll see what I can do to lighten them a bit.
  12. The BEAMS and the ke70 finally met each other today
  13. Do you know where I could find the bottom half of the extractors? If so, rough price?
  14. Would love to register it, but just going to keep it as a track car. Original plans were to put a 4age in it and club register it so it would be for road and track, but changed my mind. I hope it goes like a rocket when I'm finished.
  15. As long as the doors stay closed, nobody will know.
