AE70Rolla
  1. Hey Banjo, my original cluster was lost when moving houses and i did not note what type of cluster it was, either way I'm still confused as to why i have two cluster plugs and then 2 small random plugs. I'm currently trying to wire in another AE70 cluster that came out of an 81 also. all of the wiring diagrams i have seen don't seem to match the wires i have coming out of the harness, heres the cluster I'm trying to install. Hey AltezzaClub, I don't seem to have the yellow/white wire anywhere in the harness otherwise i have the wires you mentioned spread between two plugs but am still very confused what the other two small plugs are for... do you have any idea what they could have possibly been plugged into?, is it possible for the dash to work with only 2 out of 3 plugs plugged in if wired in correctly or not? I took a photo of each plug with wires that are in them and will write what colour they are above each photo as you may not see some of the coloured stripes, if your able to give me your advice on what to do would be greatful as dude Colours from Left to Right: Black/Orange, Yellow, Yellow, Yellow/Black, Red/White, Red, Yellow/Blue, Black Green/Yellow, Yellow/Red, Green/Black, White/Black, White/Black, Yellow/Green, Red/Blue, White/Black Blue/White, Green Red/Green, Pink/Blue, Red/Green Once again any help is good help cheers team.
  2. Hey team need some help tried looking all over the net and can't find what i need, Currently trying to install my speedo cluster into my 1981 AE70 sedan but have a slight problem. There is ment to be 3 connector plugs leaving the loom into the back of the dash like the first photo. In my car i have 2 of the 3 plugs but where i should have the 3rd one i have two smaller ones that don't fit in any kind of way and have me all confused on why they are there and what they would have been for(see second photo). Any ideas on how to fix would be awesome or if anyone has any type of wire diagram so i could try wire in a normal plug Cheers
