26rolla
Everything posted by 26rolla
  1. thats weird ive put a ae86 lsd in myne and lowerd it 3 inches and i still have 3 inches untill it hits floor
  2. oh mean thanks how much did that whole pedal box cost? and whered you get it from i needa run something like this on mine thanks heeps and can you run boosterson them do you no?
  3. What pedal box is that? cheers!
  4. hey davros are you putting an injected 4age into yours? I'm putting a 4age with side drafts in mine and the space is verry limited I'm having to make up a pedal box
  5. I have a set of 15"s for my ke20, they are simmons. 15x7 don't know the exact offset, were also on a mazda r100 and rx4 The front ones do not fit because the lip around the dustcap on the hub does not fit inside the back of the simmon. I can get them 3/4 onto the studs. It is out by 1-2mm, I found this I found these http://www.autospeed.com/cms/A_2242/article.html Has anyone dealt with this before? Any solutions? Is it possible to machine down the lip on my hub to match the wheel or is that not advised? Any other easy hubs I can fit that may fit these? Also, if these wheels are hubcentric and are meant to be supported by the hub and not by lug nuts which other wheels are, isn't it bad to put these rims on the back which features drum brakes? Because then there is no support for the wheel and you are practically putting all the rear end weight on the studs.. Or am I wrong? Any help appreciated.
