55LDE
Everything posted by 55LDE
  1. nah mate, bought this stocko in 2006 for $300 :D
  2. but i need more camber :D would lca fix this?
  3. Front end lowered. has dropped more since then.
  4. my diff in my ae71 with 4ac is pretty shagged and i found a ke70 manual diff will these bolt in the same and the brakes fit on from the ae diff? cheers steve-o
  5. it was a tin of chassis black lol, i put a clear on it and we got the settings wrong now is rough gay lol yeh ill need to cut it back and throw another clear over
  6. AE71 [55LDE] Project AE71 Spirit 4A-C 5spd Manual 1.6L Iv had this for about 3 years now and its been sitting in a paddock for like a year and decided to get the old girl back on the road. So whats been done: New exedy clutch kit New timing belt kit New rear main New tappet cover gasket New plugs New air filter New paint job New 2" custom made exhuast Skyline R32 Front seats up grade (yes the bolt in sept 1 bolt just drilled a new hole) New taillights Things to do: Diff it a bit noisy so look into that upgrade the suspension Pics:
  7. well I'm happy with was not some thing worse
  8. YAY its fixed, the problem was the throw out bearing was on the wrong way, cause one side of the bearing has a lil lip and the other side don't. and we had the lip side towards the clutch cover and that was catching on the cover making that loud noise.
  9. is there 2 way that the throw out bearing should go on? cause there is 2 sides to the bearing
  10. pretty much, i found one from exedy for $25 NEW
  11. never mind :P just ordered some from Toyota they has some in stock right there lol got quoted on a release bearing $90! what a rip!
  12. Where would i get these clips from?
  13. we did find when we took the gearbox off one of the clips that holds the throw out bearing onto the fork had come off. We put this back on and bolted her back up and was running good for about 5 min then the noise came back. could be the clip has fallen off yet again not sure :P
  14. how do u adjust this when its hydraulic? Yeh she drives sweet !
  15. pushing the clutch in stops the noise. Yes it was all greased up.
  16. Hydraulic. Yes Flywheel machined. No i didnt change that bearing, just the throw out bearing. This was working perfectly with no noise before the gearbox was removed.
  17. i just changed the clutch in my manual 4ac with a new excedy clutch kit and since we put it together the gear box is making this loud squeel on idle and when u push the clutch in the noise goes away, so i thought its the throw out bearning so we took the box off and put another bearing in and its still making the noise :-( any ideas? we have used a brand new bearing and a old bearing and both make the noise. before the clutch change it was working all good.
  18. AE71 4A-C tappet clearance ? is there a Work Shop Manual? What are they? Cheers Steve-o !
  19. i got 62hp out of my 4ac hahaha with 350+k's on the clock
  20. ok kool thanks guys!
  21. yes they are the flat kind
  22. Hey guys my mate has a 1983 KE70 and we want to change his bulbs to HID's but are unsure sure what bulb size it is, i went to take it out and it looks like its a sealed head light with a H4 plug on the back. where can i get new head lights that you can get that lets you put a H4 bulb in? Cheers
  23. Hey guys i need to get a new clutch as mine is slipping and i was at repco and they asked what size was mine and i have no idea. What size? 200m? or 215mm? Its a 1.6L 4A-C 1984 spirit model 5spd iv got a feeling its the 215mm Thanks
  24. Howdy All, Just a heads up for everyone about an event happening on Dec 02 at Moss St Slacks Creek, CruisingBrisbane.com and Sponsors (Hobbytime, Predator Motorsports, DGS Motorsports, PWR & NoWet) are giving away over $16,500 worth of prizes to SPECTATORS, this means you only need to turn up, register your name, and you are in the draw for some huge prizes. (Including RC Drift Cars, Motorbikes, Products and More!) **YOU MUST REGISTER TO BE IN THE DRAW TO WIN** This is an event not to be missed! For further information check out www.cruisingbrisbane.com for all the latest updates and news on the giveaways. This event is open to the public and there is no charge for entry. I've added a jpeg of the flyer for anyone interested. Hope to see a huge crowd there. :D CLICK HERE TO REGISTER one of the prizes is a Dirt Bike.............and thats not the biggest one :lolcry: All you need to do is just turn up, fill a form in for a barrell style draw. Doesnt get much easier than that :)
