23 -
Everything posted by ae92_20valverolla
When I replaced the pump in mine the sender came out first and the pump was inside the tank it was easier to remove the tank from memory, hope this helps.
Hey SCAVMAN I have a 20mm whiteline swaybar on my seca and it was one of the most cost effective handling mods I could have done. I am unaware of how it would be on a hatch.
Ae92 Corolla 4agze Conversion, Parts Needed
ae92_20valverolla replied to j00lz's topic in Engine Conversions
I had a lot of trouble tracking down parts for my 20v cv's and the like but I got most of them from toyota at Castle hill, they are expensive but it's worth it in the end because most people will try and sell you things that almost fit, in the long run it's better :P hope that helps -
Which Members Here Have Ae-92 Model Rolla ??
ae92_20valverolla replied to toycsi's topic in Automotive Discussion
Opening Circuit Relay For Fuel On S\t 4age
ae92_20valverolla posted a topic in Automotive Discussion
hello all my 20valve corolla (ae92 seca csi) keeps burning out the fuel relay which is positioned in behind the centre console near ecu and the nrma said that it shouldn't get so hot? any ideas? :P -
Ae92 Instrument Cluster?
ae92_20valverolla replied to ae92_20valverolla's topic in AExx Corolla Discussion
Thanks Bowler i'll have a look :dance: -
thats the problem then cos I don't have A\c anymore , removed it when engine was installed :dance: -
everything works except for the tacho works :dance: -
I have the mid range spec one , do any of you know how to get that to work? Thanks for your assistance in identifying the differences Bowler and sorry to be such a newb mystik -
Edit: the wrecker pulled it from a later model csi ltd and is exactly the same cluster size and shape , just the fuel is where the toyota symbol is and the temp is where the door light is on the csi dash, sorry to be a pain, I didn't even think it would be that different. -
I was wondering whether the tacho from an sx cluster should work if I just swapped it with my original non-tacho cluster? sorry if this sounds like a dumb question but my mate did it with his old hilux and it works, Thanks :dance:
Hey peoples, I own an ae92 rolla and was going to replace my brakes with the superstrut calipers but after reading the info on twincam.org about having to machinethe disc down to make it fit, i went and talked to a brakes proffessional and he said he would make up a bracket/plate which will allow the standard disc with a size of about 280mm to fit.
Ae92 Suspension Options
ae92_20valverolla replied to ae92_20valverolla's topic in General Mechanical
:hmm: Thanks for your help Nathan :D -
:lolcry: Thanks so much Nathan, do u know what the product codes were for the TRD shocks and springs and when you upgraded the brakes did you have to upgrade the booster or master cylinder? I am currently running st162r celica front calipers ,vented and slotted rotors and have done the sx rear brake upgrade, as my model is a csx , :lol: Thanks again Nathan i really appreciate the assistance and knowledge as i like to do most of the work on my car myself . -
I was looking at getting into hill climbs and track days, but the car is used as an everyday at the moment. :lolcry: -
i know you guys have probably already gone over this a thousand times but i was wondering what suspension i could/should run. Currently i have whiteline control springs all-round, with standard monroe gt gas shocks. Sorry if this has been a faq but any assistance would be much appreciated. Thanks :lolcry:
4age 20 Valve Silvertop Ticking
To have the car back on the road it cost about 3200 including the engine :) -
Thanks guys :lolcry: , i was talking to the guy that installed it and he said that there is a seal on the back of the original pulley, does anyone know about this? if i get toda cam pulleys would i need to disconnect the vvt -
Thanks rollaboy :P so this will not be detrimental to the operation or life of the engine? i really appreciate the help you guys are giving me its awesome. :y: -
Thanks little red spirit :y: , that makes sense because the engine had about 80,000kms on it before it went in and we changed the timing belt seals and water pump i didn't even think to change the pulleys do you know where i may be able to find a solenoid because i can get toda cam pulleys if they would be a good upgrade -
Thanks soooo much :y: i was really getting paranoid about it because i've only had the engine in for about two weeks, should i replace the cam pulley or the solenoid? -
Hey guys , i just had a silvertop engine installed in my ae92 and was wondering if you guys could help me out. when the car is warmed up and after driving it hard for a short period it starts to have a constant ticking noise which speeds up and slows down with the revs, should i be worried? and if so what can i do? Any help would be greatly appreciated. thanks
awesome conversion, what sort of brakes are you going to use to pull it up?
