yohann
    60
Everything posted by yohann
  1. sorry about the leech on the tread. i installed rear coilover on my ke70 I'm runing on them for a couple of month now. didnt seem to have a problem untill now, and I'm driving every day with it on kinda bumpy roads. now lets say your all right, the top mount isnt a problem to reinforce, but does anyone know how to reinforce the bottom mount. P.S- front coilover bolt staight on the ke70, with no need of changing the steering arms! i install mine without any modification at all! I'm using the D2 by the way
  2. ok so litleredspirit what should i buy i have now a ke70 auto pedal box on the car of course. will that do the trick? http://cgi.ebay.com/ebaymotors/WILWOOD-HAN...eQ5fCarQ5fParts or that http://cgi.ebay.com/ebaymotors/Wilwood-Rac...eQ5fCarQ5fParts
  3. can anyone suply any pictures.cause its a litle confusing
  4. can't i use the original auto ke70 box.that what i have now and just get a ae86 or aftermarket clutch pedal and fit it to the master cylinder?
  5. hey all. its a litle hard to find those.wondered if i could use a T18 or a celica pedale box.? thanks!
  6. thank you mate you helped me alot my next question was were are they located on the car but you answered that thank you again1
  7. hello i would like to know i saw on D1 and so on some corolla's an 86's in incredible angles and you see they've got some insane caster ive checked it in autodata and its says that i can't adjust the caster anyone know how do they do it? thank you
  8. http://picasaweb.google.com/yohannquaziz/C...ey=u-wrexqEXEE# heres some photos how can i chack to be 100% sure it will work? thanks
  9. so your saying if I'm bringing the 4afe ignition coil+igniter+modul it will work?
  10. thank you mate any how..already been there and i already know what I'm against just the first question i need a answer
  11. if you don't know charmant is the same as a KE70 by the way! thanks
  12. hello I'm about to do the all known convertion i know i was already in the 4age into ke70 convertion but i need specifique details 1.can i use the igntiter module and ciol from the 4afe?because I'm kinda the only person I'm my country with that engine and i can't go to toyota to buy parts for the 4age cause they don't know about this one 2.heres a couple of pictures of the engine iknow its a red top but can you tell me exactly what do i need to change exept the manifold cause thats been taking care of http://picasaweb.google.com/yohannquaziz/E...ey=BuIZLieSvmI# thank you very much.plz don't delete i really need some help PS.of course i know i need the gearbox rear diff and all the hydrolic clutch component
  13. ke70,, well its a charmant..but sme thing
  14. hello all. i hot two questions. first..witch fender miror do you recomend that looks good.and if someone has a pair to sell..would love to know about it second.witch front sway do you recomend.i guess a ae86 aftermarcket one..but witch one thank you very much! yohann
  15. sorry mate its the only option for me i live in a country without any coilover to buy exept for those. in addition i have no one to do that for me.
  16. hey all ive just received the d2 racing coilovers kit today now the thing is on the box it say clearly that its for a AE86 and the part code is t08 and thats the ae86 kit but what i received is different than in the picture. the front ones are the same its the rear instead of reveiving the sam and just the top and the bottom are different i got the strut that i think fits perfectly. but the spring isnt sitting on the strut but seperatly were the stock spring on the car sits does anyone knows if its suppose to be like that or they send it wrong thank you by the way.sorry if i made somekind of mistkae i new here thanks!
  17. never mind guys . i just noticed that the charmant did come with the 2T but the thing is all of them are automatic.soo but the seller that found me one..he says its from a 1600cc charmant but its a normal clutch.not hydrolic. its not a T GB right?
  18. I'm from israel thats the thing i can't go and see the gearbox..its somewhere far its a dude whos going to see it thats why he want some pictures to recognize it
  19. hello all i actually have a daihatsu charmant but its the same chassis engine ,well almost everything. anyway in my friend's book its says that the charmant with the 1600 cc engine is the 2t engine now i need a straight answer to be sure.is it the 2t engine in it if it does.that means that its a T gearbox right? can i have somekind of pictures with the gearbox in it with the 2t bellhousing to send to the seller to be sure how can i identify the gearbox?,is there any code that i can tell him to search on it? thank you all
  20. hey sam first time i see the prototype.must tell you its freaking cool!!:D anyway. for witch engine is it going to fit? will it fit my 4afe?
  21. hey mate I'm looking forward to see what comes out from your project cause i might do the same thing I'm just not sure yet thow cuase almost every thing youive done is going to cost me **** loads of cash:|
  22. exacly thanks dav
  23. thants the thing if ill need to use ITbs then ill have to use MS or somthing. so if ill use that ill put 4 coil that runs on a wheel with a sensor.and then ill overide two problems at ones. the thing I'm really woried about is the oil sump.if its made from aluminium then it will cost me my eye out. can you check for me? do you have msn messenger?
  24. accually ive seen you tread. nice work on the 20v ill need to do the custom mount cause it is very hard to get parts for cars her in israel so croosmembeor r and suff like that i don't want to try even its the only toyota engine that i can get her,that and the carina 3 engine, and i prefer this one i understood that i need to change the distributor,the inlet manifol cause its facing the firwall and the oil sump, is this right?
  25. and what modification am i looking at. custum angine mounts,change of the egnition system....what elsE? thanks
