adke11
    15
Everything posted by adke11
  1. One question that I do to adapt the rim weels stariun mitsubishi corolla wagon back to 1983. not stick to the edge of the weels, which measure the differential should have long
  2. this is the place that produced the research for Datsun Yella Terra Race Rocker Systems :yes:
  3. ay brother in Australia who built a site for Datsun A12-A15 when you get the information sent. I am also looking for ways to build
  4. check out this direction in the USA Web Site: http://www.toyheadauto.com
  5. what model corolla You can adapt a ke10 - ke11
  6. brother thanks for your interest I am going ahead with the 3k automatically. My first translation was used http://babelfish.yahoo.com/ harun and did not understand. Use Google translator hermano gracias por su interés voy adelante con la 3k automática. mi primera traducción fue usada http://babelfish.yahoo.com/ y harun no entendió. uso Google traductor
  7. Thank friend you understand me. La transmisión del 3k aguantara el empuje de un motor 4k Turbo, a parte de subirle las revoluciones al convertidor a 2,000 RPM que mas se le puede hacer.
  8. tipo lo que hablo es español , no entiendo mucho ingles. lo siento si no entiendes. lo que quiero saber es como traducir mas pawer ala goma con una pawerglider 2 cambios. o si debo adaptar la del modelo 2tc. que debo hacer muchas gracias tradúcelo
  9. I have an automatic trasmisión 2speed to pawerglider of the motor 3k, that I can make to transfer but to pawer to the kw with that model, said to me that 2t- 1973 - 1974 adapts one of the model - 2speed not if it can. if it could that I must do I will be thankful for the aid thanks
  10. Hi, HIGH ROLLER. I live in Puerto Rico i have TE 70 1.8 turbo two carbi 48 , Toyoglide 1970 4k turbo EFI Home made.
  11. friend thank for you interest, I am beginning in this type of motor. I am turning it I turbo, but I have another question my ke11 is automatic of factory I am going to raise revolutionizes it to him to the converter of the transmission to 2.000 rpm. that I must do so that the transmission holds the push.
  12. friend many thaknk, soon I am going to place pics of my project 4k Turbo
  13. I need the original antenna, my group of people is two doors I need quarter vent seal, oil CAP. original, real bumper
  14. Precious friend car, I have an original ke11color white that I have been years recovering but in my island pieces are not obtained. as I can obtain rubbers of the curtos ventilators of the doors, I need other pieces contáctame email [email protected]
  15. aid I need to know if the Cám shaft I can you turn it to hydraulic engineer to lifter solid and must not have problem. Adrian thanks
