Ke25 Coilover Mods Shocks And Coilover Sleeve Kit Install
Jono are the ae86 coil overs longer or shorter in overall length do you know to a standard ke20-25 strut/shock ? sorry I mean the actual length from top to bottom not the spindle itself.
Its just like a caravan wheel Jono, but my wheel has been machined to suit certain size bearing etc, so if the ae86 spindles are a different size (thickness) or width (where the inner and outer) hub bearing sit then they wont work.
trouble is this is my car it isn't a ordinary street car.... need to work on what I have described for a number of reasons. I'm using spindle mount wheels also.
Hi, yeah well when we adapt the otomoto sleeve kit we will shorten the struts 40-50mm I t would think.
so the mk1 gti golf shock is the only shock insert that we know will fit the ke20/25 strut housing?
Hi Guys, Currently carrying out a coil over mod on the front of my ke25, using the otomoto coilover sleeve kit and k-mac castor/camber plates. What shock inserts have people been using with this sort of a setup in the front end of the ke2/25? Do ae92 shock inserts work? Thanks guys
Ke25 20B Rotary
pics soon guys just getting the last of the body prep done before we refit all the wiring and looms etc.
Ke25 20B Rotary
car is now finished....
Change Of Mind 3Rz Into Ke10
The front leaf spring haha
I was thinking of changing the leaf springs to white line sway bar
Nah tally that's my brother his still going for that set up I am just wanting a tough street car
What diff is the best I was thinking hilux, vl turbo or r31 With a powerglide wondering what to with the front leaf spring
13B Into A Ke10 Hard ?
Bit of a different price range between us haha
That was my brother that done the 20b conversation , I am Doing my own 13b into a ke10 conversation
Yeah lookin into it for sure what diff and gearbox did u use
