Ok so been scaning the net for the last several months, trying to sorce as much info as i can,
basiscly i have a 1980 ke55 , my daily driver, i want to put a ca18det into it ,I'm finding alot of conflicting info and people have done this and done that ,can't seem to get the whole picture tho ,so can any one who has done this or has a mate with this done offer up some info to clarify what ive learnt so far???
so this is what i have : the ca18det will fit into the engine bay no problem, as for the engine you just have to make up engine mounts to fit to the standard x-member?????????????????????????
you don't have to cut the firewall or the tunnel at all when using a standard s13 ca18 gear box?????????????????
as for mounting the gear box you can just make a custom xmember to suit,
the gear stick will sit 3-5 inches back from the standard hole,so just cut new hole and plate over the old????????????
and the drive shaft can be created from a datsun drive shaft using various yokes?????????????????????
and the other thing the diff?? now ive read that you can use r31 skyline diffs, with one side cut down and the axel shortened to suit, cut the old mounts off the rolla diff and mount them to the r31 diff,?????????????????
and the other thing the front strut/brake upgrade , ive read all sorts of crazy combinations but what realy works well???????????? i need bigger disks and bigger calipers ,but also changing the struts may well effect the camber,
ive read of people using ra60 struts , with ke30 lower balljoint arms?????????? xtcorona???? realy a bit lost with all this wealth of info
can any one shed some light on the things ive read and comfirm if they are correct, maybe sugest a good way to do things ,
pretty serious about this build ,but want to be armed with correct info before i take it all on,
all pics and info welcom !!! help me get this thing started! :bash:
