Everything posted by polaegame
Ke70 Front
Sweet. If I do the coilover conversion and drop 40mm or so will I have much issue with the standard travel on the inserts?
Ke70 Front
Great info guys thankyou. I just picked up xt130 struts hubs brakes and lcas, getting delivered. My issue now is what springs should I run? What sizes from other cars can I get for a stiff rate?
Ke70 Front
Front needs more low and stiff, I'm going to put it to the floor... Should I: A. Get chopped stiffer springs and tie them in (illegal) B. Weld on a sleeve coilover kit (no good choice of insert) C. Wait for some hachi struts to come up on Gumtree (expensive if it ever happens) Any other ideas appreciated! :-) Also sorry about the pun at the start.
Need 18R Carby Help Please! Not Idling/running Properly...
I suspect because of the choke though, because it appears to idle and run better when I choke it with my hand. MultiQuote
Thanks for the advice everyone, I'll let yous know how I go tomorrow :)
it does, it was very high, but i've adjusted it now it sits just above half way. I will try that, should I buy new gaskets and that? A rebuild kit is 70 bucks plus I gotta wait for it, would rather fix the problem tomorrow if possible of course.
Uploaded with ImageShack.us
G'day Starski here! I know this isn't corolla specific, but I always get the best help from this forum. Bought my new 1981 Hilux over the summer, and has been running great, please check out the picture attached. Anyhow... now it doesn't idle properly after running for a while, it's fine at start up but then won't accelerate properly and conks out at idle when I'm stopped at the lights. I've tried adjusting the float level, timing, idle and idle mixture, and blocking off vacuum hoses for all the emissions rubbish, but all to no avail! My dad reckons a vaccuum leak somewhere but I can't find it... Just yesterday it start running even worse, now when I apply partial throttle it craps out, I have to rev it heaps just to get it going, but it stalls itself constantly, and it back fires when it's running constantly. Any help or suggestions appreciated, it's a Nikki carb if thats of any help Thanks Starski
Reconditioned Head 4K-C, Just Need Help With One Thing
thats great thankyou, i can only find one nozzle coming out at the bottom of the right of the carb, is that where I put the charcoal? and no idea where the dizzy vac tube goes aswell.. in the diagram theres four... you wouldnt happen to have photos of your setup would you? thanks heaps for responding ill have another look tomorrow, going to pick up a torque wrench am super excited! will put up photos of the head in progress, never seen a head so clean! have to enjoy it before the new oil goes in., might paint the rocker cover if i get time.
hello, Just got my cylinder head reconditioned, and am waiting for a torque wrench before i can put it all back 2gether properly. just one quick question, all of the emissions control vacuum hoses are a mess and I'm pretty sure where wrong to begin with, I've consulted my gregorys repair manual and it gives no clear instruction on what goes where. I'm willing to leave it all off for simplicities stake, but am wondering if anyone has a photos of a correct setup, or at least where the vacuum advance from the distributor goes. I would like if possible to put it all back to stock specification. Any help regarding the vacuum hose/carby/emissions control apreciated.:)
4K-C Not Starting, Any Pointers?
thanks so much for all your help guys, gonna get into it weekend after this one, just one last question... will I require any tools to get the head off that couldnt be found in an ordinary tool kit?
sweet thanks heaps, what is skimming? does skimming require special tools?
G'day fellow rollaclubbers, Recently lent my OVERHEATING (i know I'm sorry never again will i put it off for so long) ke55 4k-c to a friend who needed to get to wollongong, and got a call that it had stopped working on the highway! The report is that water is coming out exhaust when trying to start. Could this mean a cracked head/block? or can that just be the gasket? Going to attempt to check the head asap, anyone have pointers on removing? has this particular thing happened to anyone before? will get the cooling system/thermostat checked proffesionally once I can start it. If its nothing too serious... any help appreciated! Please enjoy photos of the car in my gallery, I bought this car for $280 and its served me so well for 1 and a half years til now. I hope this isnt the end for jolene...
Radrollaz Cruze Sunday 28Th November
will be there with bells on
Spotted Red Corolla Castle Hill
lol that was me mate, just got my p's yesterday, hit us back and we'll go for a cruise 2 the gorge one night.
Ke55 Leaf Flippers In Sydney
Does anyone know a place in sydney that will flip and stiffen the rear springs of my ke55 sedan? I also want to cut my front springs, any better options? any suggestions appreciated
Ke55 Suspension
Hey all lookin forward 2 toyota nats? Wondering if there's and off the shelf/wreckers option for low stiff front springs for my 81 ke55 sedan? and how do you get the same result with the rear? I know you flip and add extra and reset but I don't know what this means, is there someone in sydney that does it? cheers for any help.
Ke55 General Mainenance Tools
Hey guys, been working on my KE55 Sedan trying to get it in tip-top shape, but I realised I have no tools of my own. What (in your opinion) is a good, cheap, reliable brand of tools? Looking to buy a set that hopefully has everything, plus a timing light and dwell/tachometer etc should i just go to repco or are there exotic brands that I should look at? any suggestions appreciated. cheers. EDIT maintenance sorry guys,
Ke55 Sedan, My Baby Project
FIXED thanks for your help guys! Yep it was the dwell timing on the dizzy and the points, we also gapped the spark plug and shes now running like it was 1981! now to get the exhaust pipe welded (broke in half some how?)
Hey this is my first post on your awesome forum (that so far has been helpful) but I couldnt find anything on this particular problem. KE55 Sedan 1981 4-KC stock Is not acclerating properly?? I can go up 2 100kmh if I gingerly apply the least amount of throttle properly, but if I try and step on it it just craps out runs badly and sounds like a victa mower with a hole in the exhaust. I change fuel Filter, but was wondering if there something else I can check simply b4 ripping my carby apart? note, seems to idle a TINY bit higher when I twist the dizzy cap slightly clockwise, but it doesnt stay there. please enjoy gallery photos of my trip 2 byron in the newly registered rolla with brown vinyl interior got from a wreckers. Any help, comments appreciated.
