spikey
    10
Everything posted by spikey
  1. I have got a JDM 67 shovel nose Corona 2 door coupe, it has factory a/c in place of the glovebox and am only auto search radio, it comes with a 2R engine and 4 speed floor shift, I will post pics later.
  2. I have been told I few people have done this same dash cluster conversion, i just need some info on what was needed to wire this up, any help would be greatly appreciated, if you have a wiring diagram it would even be better. Thanks Terry
  3. Has anyone done this? I'm having a problem with the timing on this setup, when you rev the engine it retards the timing for 10 degrees to 5 degrees, doesn't make a smooth drive, are the computer setup differently on the ae112 computer, any help would be much appreciated, Ae112 ecu pin out would be great too. Thanks Terry
  4. That would be good if it was just the thrust bearing. Thanks
  5. While you are shifting up through the gears there is no problem or sound, but if take your foot off the throttle there is a grinding sound from the gearbox near the passenger footwell, I'm thinking it could be front diff problem, anyone else has encountered this problem? any help would be appreciated.
  6. Has anyone done it here? is there an easier to get the rack out without having to drop the engine? Thanks Terry
  7. Would a AE92 steering rack go into a AE95? Thanks Terry
  8. Happy New Year!!! I just tried it yesterday and it now works a treat,Thanks Robert Terry:)
  9. I have just replace my non tacho cluster with a tacho one for my Ae95,everything works except for the tacho,does anyone which wire I'm missing to get the tacho to work ? Thanks Terry
