andrewly
    26
Everything posted by andrewly
  1. Thanks Banjo, I'll give them a holla
  2. Hey Guys, Bumping this up - I've been MIA for the past few years the Suzuki has been out no more than 10 times since and wanting to pick my hobby back up All i want out of this build is EFI, an angry sounding motor and to potentially swap out the 5th gear with custom cut gear as its a bit tall (Approx 4500 rpm @ 100kms). Not chasing huge power but hoping for 100hp. I don't quite have as much time as i used to and if i tackled this one solo it would potentially be in the garage for another 10 years before its finished. Happy to share my budget via PM. Thanks, Andrew
  3. Hey guys just a quick question on this - Been researching a bit on bike carbs and interested to know if anyone has experimented with 1 single bike carb? The reason why I want to go down the bike carb route is because they are CV style and can handle angles pretty well (for steep hillclimbs and wierd angles for 4wd) The kit I'm looking at accomodates 40mm or 44mm Harley Davidson carbs and looks to be something you bolt on an existing manifold. http://www.lowrangeoffroad.com/suzuki/samurai/engine-upgrade/sidewinder-suzuki-samurai-cv-carburetor-installation-kits-40mm-or-44mm-seu-cvck-40-seu-cvck-44.html Is there more of a gain to be had with four carbs over the one? I realise the link I gave is for a suzuki sierra and their carbs are on the other side of the engine but i am pretty sure they share the same bolt pattern for carbs.
  4. Hi Mate - thats what I do intend on doing how ever was hoping the engine builder can give me some more specifics on what I need to buy etc.
  5. Hi Guys, Can anyone please point me in the right direction on who would be able to EFI my 5k in Melbourne? Preferably eastern suburbs but its not really an issue. I haven't purchased anything as of yet and wanting someone who would know which bits and pieces to buy and install/wire up. Thanks and apologies if this has been posted in the wrong section
  6. This rig is beautiful. I couldn't bring myself to sell mine to buy this. Are the plans to club rego and drive? Will this rig be seeing any rocks?
  7. I have saved up a bit more $$$ and now looking at different options. Put efi on to the 5k or drop in a 7k Can anyone recommend an engine builder who would be able to put this in + carry out a few other mods etc? Also - I already have an engineers certificate for 5k engine conversion for my zook. Will I need another engineers certificate if I out in efi?
  8. Hey guys I did a compression test on a cold engine just to see what base I'm starting with. Dry 155 170 165 160 Wet 170 185 180 180 Largest variance for dry test is 8.8% (155 vs 170) and largest for wet is 8.1% (170 vs 185) Is this still ok without a rebuild? Just looking at my next steps to take as I have blown an inlet manifold gasket and rig stalls when idle. Plans - a cam of some sort, need to do further reading and make some calls to the cutters and full exhaust. Hoping to get away with just a little under 1k for these items. Am I being to optimistic? Or would u just not do either and go straight for EFI? Finally does anyone have any recommendations for shops to goto on East Melbourne?
  9. i read in a suzuki forum that some people have been putting 4k carbs on their zook engines as an upgarde so thinking putting a zook carb on my 5k would be a disadvantage. would an electric fuel pump do any justice to fix this? at some stage in the future (when time permits) i will be doing a comp test on the engine and hopefully pulling things apart. will be my first time pulling an engine apart so will be fun and games. i did do a comp test previously but had no idea what i was doing and turned a blind eye afterwards haha. plan is extractors, 1 3/4 zorst and a cam. but things may change :) efi is certainately on the cards so i will be doing a lot of reading in the coming months
  10. Hi Leigh, Loving the high top that you had and 6.5's are awesome!!! was my first mod. I have thought about doing a RUF but still have other things i wanna do to it before going for it. Pretty happy with my flex with this set up anyways. Please see below: Did you use the standard toyota carby on yours? my car keeps dying on steep inclines.
  11. Hi All, Just a small intro my name is Andrew I’ve always been keen to learn about cars and didn’t quite have any hobbies so I put them both together and started off with a 4wd. Always had a soft spot for zooks since I was a kid and I needed a car that I COULD NOT speed in for a year so the LWB was perfect for me. Best thing about zooks is how cheap some of the parts can be had for. I accumulate all my spare change and buy most of my parts from that! I used to own a couple of corollas – had a 03 Model corolla sportivo and then had a granny spec KE35 so was even better when i heard there was a corolla donk in here Set up when I bought the car a few years ago: Suzuki Sierra 1l lwb Toyota 5k engine with lengthen/shorten jack/tail shafts T50 gearbox Standard transfer case 1 litre open diffs Front and Rear Drop shackles 31” Cooper Discovery ST’s Before: Current Set up Upgraded 1.3 litre wide track diffs, chromoly front axles with auto lockers fron and rear 6.5 ratio transfer case Winch 2” body lift Front drop shackles changed over for extended shackles 31” Silverstone Xtremes The list goes on…. I have had a massive learning curve over the last few years in regards to the driveline etc and learnt a lot about my car. I will be looking into playing with my engine now and should be lurking around a lot in this forum to get some info. I have a build thread in another forum but will try and update this thread according to engine related stuff - and maybe the odd flex shot ;) Merry xmas everyone!
  12. So i took the advise from kickn5k and took my stuff to a brake and clutch shop and it got matched up to clutch disc TYD008U The disc is a little loose on the spline however everything got sorted in the matter of 2 hours including throwout bearing. Happy times installing it now - thanks all
  13. ah - got ya thanks mate
  14. I see your point Taz, I must be missing the retainer part which is a bummer. The whole engine conversion of my rig is a nightmare. i have got a welded (not bolted) cross member and the engine had to come out for the gearbox to have enough clearance to come out. I might go and hunt around the wreck yards and see if i can pull off a 180ml flywheel of a corolla and look for the retainer clip infront of the box. I always thought the hacked bellhousing was to accomodate for the clutch fork being pushed back and forth. the original dust boot was ripped to shreds and barely covered the hole. I made good use of a HD rubber glove and a piece of leather for this. So if the flywheel was 20ml smaller (180ml vs 200ml), wouldn't the starter motor not reach the flywheel once all put back together? Another thing i want to make abosulte sure of before i go down this path is to know that the 21 spline clutch plate will fit on directly with no play (TYK-6280 (K50) 21T x 24.1ml x 180ml). I am pretty sure my measurement was pretty accuarate, and if it wasn't it should only be 1ml difference. i apologize if i'm completely wrong above the above statement, this is the first time i've played with clutches/gearboxes. edit: I have been reading up on some other sites and people have been pointing to the KE74 clutch disc which is the above mentioned TYD008U. I might give that one as my last shot and go from there.
  15. Thanks for the repsonses guys, I was trying not to go down the route of not changing flywheel as I have just got this machined. The 21 spline set up from exedy looks like it is going to be 2ml difference so was thinking there would be too much play. I do have the 200ml flywheel. Are there any potential issues in going down to a 180ml flywheel? Clutch plate has is getting sent to exedy to see if they can match it up with anything and if not they will quote me for a custom job. Has been a real pain in the backside returning all these different clutch plates to a vendor that deals with exedy. Another thing i want to ask is are there meant to be any retaining clips for the throwout bearing? The main reason why i am going for the clutch change is because i had a very loud throwout bearing. When looking at it,it was just seized on and i had to hammer it out. appreciate the assistance guys. gotta love dealing with engine conversions :)
  16. also am i right in saying that its not a K-T50 gearbox if the clutch spline is a smaller diameter?
  17. Photos are attached Please don't mind my hoarders style garage and yes the gearbox is pushing those tyres in the background :)
  18. Hi All, Was hoping some Toyota gurus are able to help me out on my clutch problem. I believe I have a 5k engine mated to a K50 (5 speed box) and need to get a clutch replacement kit for this. Originally i bought the clutch kit that suited the KE70 4k and found out that it had a 19 spline input shaft compared to my 21 spline shaft. I can't find the correct clutch plate that will fit my gearbox. Dimensions of the gearbox 21 tooth spline are: 21ml outer tooth and 18ml inner tooth x 200ml. I have done a search on the exedy website for the rarer K50 21spline clutch place and the dimensions seem to be out by about 3ml. It had also crossed my mind that i may have a K-T50 gearbox but even those parts don't match. Part numbers i have tried are the below: TYK-6280 (K50) 21T x 24.1ml x 180ml TYK-6319 (T50) 21T x 24.1ml x 200ml Can someone please tell me if there are any other toyota clutches i could have a look at? it is driving me insane! i can take photos of the gearbox for clarification if needed Thanks, Andrew
  19. Ok - so got 1 on order and for $11.20 woot woot! Rang up 3 different stores and found out the guys can order the stock in but were too lazy to do it for me yesterday. Was a little more forceful today and they are getting one in for me! Thanks guys for your help
  20. Hey Evan, Had my eyes glued on this forum for extractors but with no luck! I might check out some exhausts shops soon. I'll just bursons another go tomorrow. Third time lucky they say Also thanks kickn5k I quoted that number first and they said they didn't have it then went with the em30 Am I wrong saying that a 5k comes from a rolla? I'm sure they come in corollas but everyone says there is no such thing and that they are in vans which I already know.
  21. Hey guys - in need of one of these gaskets and called up two different Bursons and they said they don't have EM30?? The closest they have is a HA055 which is a two piece that doesn't look as thick. I then called up Repco and they said they can get them in but it will cost $20 for the part and $10 frieght with me paying up front! Is there another place where we can get these? Thanks
  22. I bought the car with the conversion already done – maybe I’ll check the engineer’s certificate later when I get home. Maybe a max of 3 years? 100% sure that it is a Toyota box but don’t know which model box it is. I’m guessing there is no quick fix to get my compression back up on the one cylinder? I had a mate of mine say that it should be fine as long as the other 3 are normal… I guessing that is a bunch of b/s? The motor itself is not chewing through oils or blowing out smoke so I'm not sure what is going on.
  23. Sorry forgot to add that i've also done an engine compression test and got 200psi of 3 cylinders and 150psi on the last cylinder. Could this be the reason?
  24. Hi Guys, This is a bit of a random topic but hoping you guys would be able to help me out here. I have a Suzuki sierra with a 5k engine in it. I've got 31" tires on them at the moment and it really struggles to see 100km's. Speaking with some suzuki guy's and they reckon something is playing up as the standard 1.3 litre's (G13a) can go in excess of 100 with the mods i have. Running gear i have: 31x10.5 tyres 3.9 ratio diffs (I think) 6.1 ratio Transfer case Is there any more info i need to calculate what top speed i should be getting? I have done a fair few things to make the car be a bit more drivable - Carby rebuild, replace spark plugs, engine oils, GB oils, oil filter, replace air filter etc but was hoping for a bit more? am i expecting too much out of a 5k? Thanks for your replies
  25. Those engine mounts would be really helpful. i will be needing them for a KE35 so if you can PM me or even let us know an esitmated time you will be doing these? Thanks!
