4k trike
Regular Member-
62 -
Everything posted by 4k trike
how do i lock it? small dob of weld???
i need help retarding the dizzy on my 4k s/c can i use a unit of a blown carbed dizzy can't afford a $500 msd unit are there other options :) :lol:
thanks taz i think he was going to run 24 ish degrees on the dizzy ? whats lock the dizzy is recurving costly or time consuming what would you recomend
found a video of the charger going and piped un rebuilt un timed and un tuned just slapped together to see if its all good very slow of the line but gets going the new front forks are great Taz_rx - I fixed your link for you. :)
um id have no idea please explain iv got a sorta mechanic mate helping very open to other suggestions/help/info thanks
cheers taz that was with old points dizzy got eletric dizzy fitted now it hadent had timing adjusted from n/a
finally found some footage i took of the trike its with the super charger piped but before i striped and rebuilt it its at you tube search sam4ktrike supercharged how do i put a link on here staight to it ??
been paint and assembling yellow looks ok with the purple even better in the sunlight now the hard part putting it back together with out scratching anything
That sounds a bit agricultural
been painting frame and acceserys ? colour looks good in the sun light bit more clear and paint front forks and paintings done rebuild front wheel,get extractors,starter and few small things and its a goer
Been busy, rebuilt the motor, painted the inlet pipes, ready for frame painting and assembly. finally got the electric dizzy.
rebuilding a stock 4k but need rod and main bolt tensions thanks
i race it in western vic/ south east south australia
yeh getting them done ive been a bit slack
got rebuild kit and paint the other day got 4weeks to get it painted,rebuilt,assembled,tuned and run in if anyone want me ill be in the shed
ive been busy got front forks fitted there good got motor going with supercharger it needs a good tune and timing adjusted striped trike and motor today time to rebuild paint and assemble:evil:
about to rebuild me 4k what is standard piston size cheers :thumbsup:
got blower piping welded up (and arc flash - not recomended ) carby mounted throttle linkage needs completing front end is getting 10 kg roadbike springs fitted next up try and start it (fingers crossed) then strip it all rebuilt motor renew gbox seal paint assemble then FULL NOISE i hope
imagine what its like to be riding it SWEET
fitted tyres and rims video footage on you tube search sam4ktrike (all one word) just built giving it a test out
tyres are 22*11*10 lugs are 27 mm
heres an update got blower bracket made to be welded better and painted blower is fitted and had it spinning (not piped yet)running sweet got atv tyres nice and grippy -yet to redrill atv rims only a small job fitted eletric fuel pump next up is su carb inlet and exhaust eletric dizzy re ring/rebuild cam$$???? front suspension also needs some work
photos 1 2 diff motor trans and front end all getting lined up photo 3 the cheif engineer/welder/tech adviser couldent have done it without him
running 3.71 diff ive heard a 720 datsun frount diff will fit 180b housing (4.87) ratio doing 3-4000 inthird over125 meters no wheel stands yet but havent got blower going its weighing in at about 455kg with me on it
