Everything posted by jnr_13
Front Park Lights
Hi can anyone help. Need to find out if anyone has a set of front park/blinker lights for sale for a ke11 corolla or if they have any idea if anything else will line up and fit in the originsl cut outs?
3K Efi Alternator Upgrade
Hi Guys, Ive got a ke11 that I'm fixing up and converting it from a standard 3k carby to a 3k efi using a manifold out of a townace. I'm sure its been done pleanty times before but just wanting some tips on a ecu? thinking of using a microtech as ive used the past and also want to know if anyone has any alternator upgrade Ideas? should I use a standard efi alternator from a 7k or modify something else to fit? regards Joe
Ke11 Lowering Help
Thanks Guys for your help. Parrot thanks for that link. Will get cracking onto it next week when I get back from holidays and let you know how I go.. Cheers
Ke11 Lowering Help
Hi guys. Am just trying to sort out my my preferred height for my ke11. Have converted front drums to ke15 discs in the front, have some ke20 front springs on ke11 front struts. Also have removed the front transverse leaf spring and will put in a sway bar. But before I install the sway bar I want to get the correct height. With the 30mm lowered ke20 springs it way to high and wondering how you guys have managed to lower the car without chopping springs? Any help is appreciated Cheers
Ke-86 Build (Not A K Powered Ae86 Sorry)
Cool Little Ke11, looks like the same colour as mine. don't see too many that colour. Have fun with the build, and keep uploading photos. I'm just starting to collect parts for mine and also slowly start the hard work.
Rear Seat Belts Required?
Hi guys, I have a 1970 ke11 that ive purchased a month ago and realised that it dosent have rear seat belts. I'm not sure if that's factory and wont be required for nsw blue slip? I have recently seen another ke11 for sale and it does have rear seat belts and now I'm a little confused. If anyone knows what is factory and what is required it would be much appreciated. Regards Joe.
Ke11 Front Brake/ Suspension Sugestions
Thanks for the heads up. yeah if you have or know any one that has any bits and pieces to suit let me know
Hi guys, Been a member for a while and have finally purchased a 1971 ke11 corolla. At the moment its original and was sitting around in a shed for about 5years. I'm planning a 7k conversion and wanted to upgrade the front brakes from drums to discs. Ive read that the simplist will be a ke20 front brake setup. I believe they also have the same stud pattern which will enable me to keep the 12inch wheels and chrome dress rims. Can anyone help as to what I will need exactly? and if someone has bits and pieces for sale. Would like to eventually lower the front and rear. Cheers
Ke10 Or Ke11 Difference?
hi guys i just wanted to find out what the differences between the ke10 and ke11 is? Also is it just my imagination or from looking threw all the ke10 and ke11 photos i could find do some have a different rear end? sometimes some cars look like they have a shorter boot and more rounded then others?? or maybe its just me? any help would be appreciated cheers joe
Timing Belt
there should be a little tensioner with a spring on it. losen it off, turn the engine by hand and then retighten the tensioner... otherwise it could be hydrolic tensioner... i can't remember which model has that... hope its a help
