October 11, 200620 yr comment_145796 just saw this story and was thinking how many people use spigot locating rings? story Report
October 14, 200620 yr comment_146313 I don't know anyone who runs them....and I'll be buggered if I can find a place that sells them...... In all fairness however, a Soarer is 1600kg AND he was running full slicks. And whos to say he didnt over tighten his lug nuts? Probably still a good idea to run them if you can FIND THEM. Report
October 14, 200620 yr comment_146321 what size inner and outer hole do you want ill get some made for you Report
October 14, 200620 yr comment_146331 what size inner and outer hole do you wantill get some made for you 66-73mm. If its more than $20 don't worry about it :) Report
October 15, 200620 yr comment_146513 you are not supposed to run aftermarket wheels WITHOUT spigot rings generally the downward load is supposed to be taken up by the spigot, and transmitted to the wheel bearing, which is designed to hold the load of the car not the wheel studs, which are designed to have lateral force applied to them, to hold the wheels onto the hub, and not an awful lot more Report
