November 4, 200620 yr comment_149482 Hi guys, I joined the forum in the hope someone may be able to answer a few questions. I don't have a Corolla, I have a 1983 Lite ace. My questions are. Is there a 5 speed available that is a column shift? Will a diff from a Corolla or another Toyota fit the liteace, something that is more conducive to highway driving? Thanks in advance Scooter. Report
November 5, 200620 yr comment_149565 Is there a 5 speed available that is a column shift? Try having a look at where and how all the linkage's mate up to the box. It's quite possible that any 5 speed that came with that series engine (is it a 'k' engine?) will fit. I know that with kingswood's, you could change it from 3 speed (with column shift) to a 4 speed and keep the column shift. All the linkage's bolted on. So I'd guess just have a look at the box, what sorta engine you have, etc. Hope this helps. Sorry I can't help you with your diff question Report
November 5, 200620 yr comment_149577 Wait until TRD Ke70 gets on, or send him a PM, he should know all these answers and more..... Report
December 18, 200619 yr comment_155934 hi mate have a 5k work van. was a 4 speed. was told that a 5 speed gear would fit in the box. did not happen but yes a 5 speed box will fit. good luck Report
December 19, 200619 yr comment_156048 In the future can you PLEASE put something more than "help" in your topic. You have been warned. Report
December 20, 200619 yr comment_156222 factory option, hit the wreckers, has to be a van and has to be a k series, you may need shifter to suit i don't think the 4 speed shifter will work Report
December 20, 200619 yr comment_156278 First you have to tell us what model car you have. Look on your ID plate and tell us all the numbers. Maybe your van is a KY30 or something like that? Don't know. Then find the Transmission code. Maybe W40, or something. So next post, give us something like this: Model: KY30 Trans: W41 Diff: E382 Only then can we help, because we don't know vans that well. Report
December 21, 200619 yr comment_156288 arent hiluxes and hiaces almost identicle underneath? if so a hilux dif would be my choice. no idea about the column shift. cheers. Report
December 21, 200619 yr comment_156318 10/79-8/85 20 series Liteace's have an E series diff. E252 = 4.556 E362 = 4.778 E152 = 5.125 E282 = 4.3 Try a YM21 which have the 4.3 diff. MX3# cressidas have a 3.9 diff centre which will fit and be nice and tall on the highway!! Report
