Ke Gearbox Question
Some K50 gearboxes come with a 19 spline input shaft and some with a 21 spline and the K40 is a 19 spline
New Ke70 Tail Lights?
Could always try your local Toyota dealer
Flywheel Bolt Length
I'll try to remember to measure one for you tomorrow
Converting From Auto To Manual ? (legal Issues)
The Victorian Police Force (or should that be farce?) don't know how to read those plates. Half of them wouldn't know the difference between a K engine and a 350 chev
Engine Oil
I've driven my ke70 with 4k for about 400kms with no water and I'm sure it had no oil as well (as over heating burns oil) and still ran that engine for 2 years after that. Only "special" people can kill K engines
3 Paint Options
Go for the Tranformers
Whats Engines Are Legal
National Code of Practice for Light Vehicle Construction and Modification (NCOP)
Act General Chat Section
Once again a HUGE thank you goes out to Steve for assisting (ok, for doing most of the work) with my grinding to a halt rear brakes. And I forgot to thank Steve last time when the ball joint fell out. That was a fun outing :) I think I should start getting the car fixed/maintained BEFORE things grind or fall out, although it is amusing to see how bad I can get the car with it still running :P I don't know what I would do with a normal mechanic
Some Changes Are To Happen To Rolla Club Act
Are these changes happening because Geoff has been banned?
Mitsubishi Production To End
So $35 million is doing nothing to assist?
- More Stupid
New Kid On The Block
Yeah, because I knew someone else had stuffed up how the dizzy went in. He has also said that it could be the battery to which I can give him a jump start. And at least i offered to help instead of "probably help out" ;)
If you want I can come over some time over the weekend and give you hand to get the ke70 going
More Stupid
If I had known this earlier, I would've dropped in and laughed as well. I was over in your area at about the time you posted this
Meetings For 2008
I'd like to know who was stupid enough to vote for Geoff or Steve. I'm not really fussed what day the meetings are on, I'll more than likely turn up
