Hi,
I have been looking at buying a Ke20, but it is auto and i would like a manual
one. I am thinking that if i bought it i would convert it to manual, but
do not know how legal this is.
I assume it needs to be checked/certified?
I have had a look on the vicroads site and can not see anything.
Does anyone know the legal process i would need to go through, and if
it can be legally done ? (or if i just need to do it by stealth and not tell them) :D
Help much apreciated,
Dougal
Just go to your local transport office ask them, but everyone I know that have done the same that you are looking into just went and did it then got the mod tagged/certified and change the vehicle detail at said transport office and insurance. That would be suffice, but you aren't in the same state. So go and ask.
I find it hard to see why a g/box change that came out of same car needs to be checked.
The only time an engineers on a swap like that is needed is when it did not come with the car orig or the crossmember has been modified.
But i will check with a mate of mine tonight he works at vicroads he will know. At worst you may just need ring vicroads and tell them you have changed to a manual.
stu.
Edited by kickn5k
stu.
Because the build plate on the car tells the police what the car is and what it should have in it, when they don't match what they see its trouble. ie engine g/box and seating capacity
Many many moons ago I replaced the old toyo-glide for a 5 speed (out of a ke55) in my ke 20. I had no issues with Vicroads or the police (who quite frequently pulled me up back then) about the conversion. I even left the toyo-glide badge on the boot lid. As long as you use the pedal box from a manual car there are no real problems. The crossmembers are usually mounted in the same spot. At least for a ke 20. I'm not sure about the 30. Oh and another thing, the gear lever boot must be sealed as to not let any gases into the cabin. I used the original boot and an after market boot on top.
LB
Edited by webers4x48
A mate of mine went from auto to manual and just told vicroads that he'd done the conversion and it was ok. Nothing was cut or modified and it was all factory gear. Its usually when its not factory and things need to be cut then its an issue.
I was just unsure and wanted to check.
Anyway, its not a problem as the car i was looking at
turns out to not be a go-er after all.
The search goes on... :hmm:
The Victorian Police Force (or should that be farce?) don't know how to read those plates. Half of them wouldn't know the difference between a K engine and a 350 chev
  • 2 months later...
lol a friend of mine had to pop the bonnet on his XR4 and let the cop search for the turbo just to convince him it wasn't there.
Haha! Not the first time it has happened either. Many of these new euro/jap FWD turbo hotties have massive plastic engine covers and heats shields making the turbo almost non-existent to somebody who doesn't know their stuff too well. (eg. most coppers)
