ke17 20v Posted November 24, 2006 Report Posted November 24, 2006 any help would be great... i have a 4age 20v with a sprinter rear wheel gearbox but no plate from the rear of the engine that bolts the gearbox and starter motor up... i was wondering if the front wheel drive plate and the rear wheel plate are the same? because i can find an original front wheel plate easily but nearly imopossible to find the sprinter rear wheel plate... any advice would be much appreciated thank you.... Quote
TheNOBBLER[RL] Posted November 25, 2006 Report Posted November 25, 2006 Do you mean the bell housing of the thin plate that is sandwiched in between the bellhousing and engine? You might have some luck with AE71 parts in both of these cases. Jarrad Quote
Trev Posted November 25, 2006 Report Posted November 25, 2006 Its been covered, Double post: http://www.rollaclub.com/board/index.php?s...mp;#entry152254 Quote
