December 8, 200619 yr comment_154243 gday i need engine mounts for my ke16 fast! i can only get mounts to suit ke30 onwards, i've searched the threads and can't find anything helpful. will later model mounts do or will it sit poorly, at all? HELP Report
December 8, 200619 yr Author comment_154250 how about custom making mounts? how do you fix the rubber to the steel? i can use the original mounts with new rubber Report
December 8, 200619 yr comment_154271 I'm sure i used ke 30 mounts to put a 4k into a ke10, motor fitted fine, but that was 10 years ago so i may be remembering the wrong car Report
December 9, 200619 yr comment_154494 you can get away with the left side mount from an '81-84 starlet KP61, it will sit a little higher on that side, but it will work Report
January 11, 200719 yr comment_158921 you can get mounts remade, ie take in the old ones and they fill it with new rubber. else try other vehicles as they could be modded to suit. Report
