4 Speed
went today to get a gearbox for my 4 agte, the guy said he had one out of an ae71 but it was a 4 speed i saw the box and motor it was a 4a, has any heard of these and how strong and if i can use it and also if i would have to change clutch or tailshaft or anything?
Its a T-40 same as T-50 minus the over-drive, It will bolt up the same and use the same clutch i would imagine, If its cheap take it.
argh I'm going to say the same thing as i did on toyknobs, f@$king search, google search any search you will find ALL of this info, otherwise how the f@$k would i know?
either its a later model t40/50 with 22 output splines or its anearly model with 20 splines, exactly the same inside and out no matter what anyone tells you. the t40/50 is missing the driven gear and really isnt worth you while go a w box cos it will last and you will not break it, pop the clutch like we all do and either your clutch will slip if not a t50 will go bang, if not (or you have a w box) your diff will go bang, and if neither of those go you axle will shear
Edited by skiddz
