just wondering how many volts my alternator should be putting out on my standard 4K
I did tell you that it should be pumping out about 14.4V or there abouts. Dunno about the bigger alternator
As I told you the other night, turn everything on, then get the reading, and if it drops anything below 13.5, then your alt isn't doing it's job.
With everything on or not, it must read between 13.5 and 14.5 to be considered "ok" anything outside that is not ok.
