blonka Posted February 26, 2007 Report Share Posted February 26, 2007 hey, I'm puting a 4age bluetop into my ke35 and ive run in2 a few problems 2 do with the efi do i need a fuel filter? and if so where should it go? it previously had a 4k in it and i can't find a return fuel line, i seen a line coming from the fuel tank and then it dissapears in2 the chasis, do i even need a return fuel line? and last question where does each thing connect to on the inector rail? i have atached a picture of it to help Quote Link to comment Share on other sites More sharing options...
Jason Posted February 26, 2007 Report Share Posted February 26, 2007 wow maybe you need to do some more reserch before you get stuck into the project.... anyway, the blue is a compresion damperner (for fuelpump) and comes from efi pump, red is the feed for the cold start injector. Yellow goes to manifold. Pink is return, which inself answers your question. Quote Link to comment Share on other sites More sharing options...
BreakDave - GT Posted February 26, 2007 Report Share Posted February 26, 2007 as above... and with filter... add it after fuel pump somewhere before the rail Quote Link to comment Share on other sites More sharing options...
Taz_Rx Posted February 27, 2007 Report Share Posted February 27, 2007 :) Fuel filters for any car, carby/efi, petrol or diesel should be between the tank and the first pump, that way even the pumps get clean fuel. to elaborate on your picture a bit: The blue one as mentioned is the fuel in from the fuel pump. on the other end, the bit bolted to the fuel line is actually your fuel pressure regulator. the small line coming off it in the yellow circle is the vacuum reference and needs to be put onto a post-butterfly vacuum source. The pink circle is for the return line as mentioned, you deffinately have to have a return line on it otherwise pressure will build up too high in the fuel rail. the regulator will reg this to a designated pressure and divert extra fuel back to the tank. Quote Link to comment Share on other sites More sharing options...
LINDSAY Posted February 28, 2007 Report Share Posted February 28, 2007 You'll also need to run a high pressure fuel pump , either a in tank high press. pump or setup a surge tank with a lift pump and high press. pump Quote Link to comment Share on other sites More sharing options...
BreakDave - GT Posted February 28, 2007 Report Share Posted February 28, 2007 Fuel filters for any car, carby/efi, petrol or diesel should be between the tank and the first pump, that way even the pumps get clean fuel. the only problem with this is that fuel actually flows around the motor parts in the pump, so after the pump u can get pieces of carbon brushes and metal from pump through the system.... so if ya wanna be ridiculously safe run one before and after the pump maybe. Quote Link to comment Share on other sites More sharing options...
blonka Posted March 1, 2007 Author Report Share Posted March 1, 2007 sweet thanks heaps guys got it sorted now Quote Link to comment Share on other sites More sharing options...
blonka Posted March 1, 2007 Author Report Share Posted March 1, 2007 hey would this pump be good for the pump 2 the surge tank? http://www.trademe.co.nz/Trade-Me-Motors/C...on-89622748.htm Quote Link to comment Share on other sites More sharing options...
Jason Posted March 1, 2007 Report Share Posted March 1, 2007 O.O they use carbon brushes in fuel pumps that quite scary.... I'm sure they would avoid using any sparking bush design Quote Link to comment Share on other sites More sharing options...
BreakDave - GT Posted March 1, 2007 Report Share Posted March 1, 2007 O.O they use carbon brushes in fuel pumps that quite scary.... I'm sure they would avoid using any sparking bush design they can run a design which may arc/spark because in the tank is nearly all fuel, no oxygen, so there is no air/fuel mixture which is able to go bang Quote Link to comment Share on other sites More sharing options...
