Ke25 Longer Control Arms - Which Tie Rods?
i have got longer control arms on the ke25, an increase of 25mm per arm and if i remember correctly is it the ra40 tie rod ends that
can be used when longer control arms are installed as they are longer in length and will fit properly, ie have the same thread on one end and same taper on the end other as the ke25 tie rods?
Edited by styler
yea you would be surprised how many you can use, you could take a look at ke30-55 tie rods aswell
cool, will have a wander around and suss it out ;)
