i have got longer control arms on the ke25, an increase of 25mm per arm and if i remember correctly is it the ra40 tie rod ends that
can be used when longer control arms are installed as they are longer in length and will fit properly, ie have the same thread on one end and same taper on the end other as the ke25 tie rods?
Edited by styler
I used the 25 tie rods end, with tie rods I think I stole some off a corona.
I just went to Kelly's and wanderd around the Toyota section and found some that fit. Most Toyota ones are longer.
