Killerolla Posted March 26, 2007 Report Share Posted March 26, 2007 Just wondering if it would be a straight forward engine swap from a 3k to a 4k or would the major mods that have to be done??? Ive already got the motor its coming out of my brothers ke70 that he wrote off. Quote Link to comment Share on other sites More sharing options...
Clapped out Posted March 26, 2007 Report Share Posted March 26, 2007 straight foward mate! if the motor is going into a ke 30? or 20? you will have to change over the drivers side engine mount as they are different and also use your 3k inlet and exhaust manifolds as the ke70's are different, other than that, straight foward! :D Quote Link to comment Share on other sites More sharing options...
camerondownunder88 Posted March 26, 2007 Report Share Posted March 26, 2007 EASY. This swap is straight fowards just run the manifolds from the original car other wise bolt in play. If you know what you are doing swap should take about 2hrs from first bolt un done to turn key and crank 4K again. Cameron Quote Link to comment Share on other sites More sharing options...
