April 18, 200719 yr comment_173072 Hey Hey, I replaced the leads and plugs on my st141 yesterday afternoon and it ran great apart from flat spots but thats the carby anyway its back to running on 3 cylinders ran on 4 yesterday. I have swapped the plugs and leads around around and 3 isnt working, Had compression yesterday and was even through all cylinders. Its firing but when i take the lead off when its running it makes no difference. So wtf maybe a valve stuck open ? Report
April 18, 200719 yr Author comment_173074 Well i did another compression test and 3 is now very low, Valves are fine so i might just rebuild the bottom end. :y: Report
April 18, 200719 yr Author comment_173102 3rd cylinders rings are gone, 4th has blown a bit of the gaskit out but still fired allright :y: and needs valve stem seals. Just gonna rebuild the f@$ker. Report
